Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Printing a Booklet (Windows)
Printing a Booklet (Mac OS)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac OS)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Secured Print
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Security » System Management
System Management
0R9W-233
You can link with a login service to restrict the jobs that can be displayed on the machine.
Required Condition
You are logged in as a user with the required privileges. (See "Setting Administrators.")
This section describes how to set display restrictions for the Status Monitor/Cancel screen.
The screens may differ, depending on the model of the machine and on attached optional products.
Follow the procedures below.
Setting Status Monitor/Cancel Screen Restrictions
You can perform this procedure using the touch panel display or the Remote UI.
Using the Touch Panel Display
Press (Settings/Registration) → [Management Settings] → [Device Management].
Specify each setting.
Specifying the Display Job Status Before Authentication Settings
Press [Display Job Status Before Authentication] → [Off] → [OK].
Specifying the Display Log Settings
Press [Display Job Log] → [Off].
Select [Allow] or [Do Not Allow] for <Retrieve Job Log with Management Software> → press [OK].
[Allow]: Allows collection of job logs using management software.
[Do Not Allow]: Does not allow collection of job logs using management software.
Using the Remote UI
These settings can also be specified from the Remote UI.
Click [Settings/Registration] → [Device Management].
To specify the job status before authentication display settings, click [Display Job Status Before Authentication] → deselect [Display Job Status Before Authentication] → click [OK].
To specify the job log display settings, click [Display Log Job] → deselect [Display Log Job] → click [OK].
