Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Printing a Booklet (Windows)
Printing a Booklet (Mac OS)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac OS)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Secured Print
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Performing Complex Tasks at the Touch of a Button: Workflow Composer
0R9W-23W
What Is a Flow?
Workflow Composer and Workflow Composer Editor can enhance the efficiency of routine and repetitive office tasks.
These applications enable you to register a combination of frequently used machine functions as a "flow" button. By pressing this button, you can repeatedly reuse the same combination of functions with ease.
For example, reducing the original, converting the scanned data into a PDF file, and then e-mailing that PDF can all be performed by pushing just one button.
Benefits of Workflow Composer and Related Applications
Streamline your office tasks
You can execute a flow of operations by pressing one button. You can save time spent repeatedly performing complex operations.
Manage flows for each user using an authentication system
Shared and Personal flow buttons are displayed when you login to the machine using an authentication system. Personal flows can only be used by individual users, while Shared flows are available for use by all users.
Set the output method
You can specify output settings, such as the file format to save in, to meet various purposes.
Register/edit flows on your computer
You can use the accompanying software, Workflow Composer Editor, to register/edit flows from your computer.
Workflow Composer is a MEAP application that enables you to create and execute flows on your machine.
Workflow Composer Editor is a Windows application that you can use to create flows on your computer.
Flows created using Workflow Composer Editor can be uploaded to a machine with Workflow Composer and edited, duplicated, or executed from the machine.
