Category Top
Preface
Digitizing Paper Documents
Scanning the Original and Sending to a Computer
Adding an Image Scanned via Network Scanner to a Document
Converting Scanned Documents into Encrypted Searchable PDF
Using an Advanced Box on the Network
Printer Driver
Merging and Printing Multiple Documents (Windows)
Printing a Booklet (Windows)
Printing a Booklet (Mac OS)
Using Profiles to Print (Windows)
Selecting Presets for Printing (Mac OS)
Specifying the Printer Driver Default Settings (Windows)
Fax
Temporarily Storing and Viewing Received Image
Handling Junk Faxes
Automatically Forwarding Received Faxes
Automatically Forwarding Received Faxes to a Computer
Forwarding to a Mobile Computing Device
Handling Files with Forwarding Errors
Checking That the Sent Fax Was Delivered Successfully
Accessing the Fax Function of a Server Machine
E-Mail
Sending an E-mail to Multiple Destinations
Using a Shared Address Book
Internet Fax/Intranet Fax
Sending a Document via Internet Fax
Receiving a Document via Internet Fax
Department ID Management
Setting a Department ID for Copying
Setting the Department ID Management on the Printer Driver
Mail Box
Practically Applying Print Data
Backing Up the Data Stored in the Mail Box
Security
System Management
Secured Print
Specifying Send/Fax Security Settings
Mail Box Security
Restricting Access to the Machine (IPv4)
Restricting Access to the Machine (IPv6)
Advanced Copying and Printing
Scanning Originals While the Machine Is Processing a Job (Reserve Copy)
Printing Files Stored in USB Memory Directly from the Machine
Creating Address Labels by Scanning Business Cards
Customizing the Screen Display
Making Favorite Keys Highly Visible
Registering a Series of Frequently Used Functions in One Button (Quick Menu)
Recalling the Quick Menu of Another Machine
Linkage Between imageRUNNER ADVANCE Desktop and imageRUNNER ADVANCE
Automatically Importing Received FAX Documents into Library (imageRUNNER ADVANCE Desktop)
Sending a Fax from a Computer (imageRUNNER ADVANCE Desktop)
Performing Saddle Stitch Printing (imageRUNNER ADVANCE Desktop)
Performing Complex Tasks at the Touch of a Button: Workflow Composer
Creating a Flow on a Computer (Workflow Composer)
Duplicating/Editing a Flow to Create a Personal Flow (Workflow Composer)
Executing a Flow on the Machine (Workflow Composer)
Top » Practical Workflows » Security » Secured Print
Secured Print
0R9W-234
The Secured Print function enables you to help prevent other users from viewing the documents you are printing. When using this function, you must enter a password to start a print job.
Required Condition
The printer driver is installed.
This section describes how to specify Secured Print settings, and print a document by entering a password.
The screens may differ, depending on the model of the machine and on attached optional products.
The screens may differ, depending on the operating system of your computer.
Follow the procedures below.
Setting a Password for a Print Job
Entering the Password and Printing
For Windows
From the [File] menu of the application software you are using to print the document, select [Print] to display the [Print] dialog box → select the printer to use → click [Properties].
Select [Secured Print] from the [Output Method] drop-down list.
Click [No].
The printing method is changed to [Secured Print].
You can also click [Yes] and enter the user name and PIN immediately.
4.
Click [OK] to close the printer driver screen → click [OK] in the [Print] dialog box.
The Secured Print Details dialog box is displayed.
5.
Enter the user name and PIN → click [OK].
The file name is displayed for [Document Name], but you can change it to a desired name. The Secured Print job sent from the computer is stored in the machine.
The user name is displayed on the touch panel display of the machine. When using the Secured Print mode, register a user name that can be distinguished from other users.
You must enter the password again to print from the machine. After the password is set on the document, write down the password and keep it in a safe place.
For Mac OS
From the [File] menu of the application software you are using to print the document, select [Print].
Select the printer to use → select the [Special Features] panel.
The [Special Features] panel is displayed.
Select [Secured Print] from the [Job Processing] drop-down list.
4.
Click [Print].
The [Secured Print] dialog box is displayed.
5.
Enter [Document Name], [User Name], and [PIN] in the [Secured Print] dialog box → click [OK].
Up to 32 alphanumeric characters can be entered for [Document Name] and [User Name].
Up to seven digits (0 to 9999999) can be entered for [PIN].
Entering the PIN and Printing
Enter the PIN on the control panel of the machine to print.
Press [Secure Print] on the Main Menu screen.
If the Main Menu screen is not displayed, press [Main Menu].
Select the secured job to print → press [Secure Print].
A locked icon is displayed for the secured print job in the job list on the touch panel display.
Enter the PIN that you entered in the computer → press [OK].
Reference Information
Linking to the Authentication Function
If the management mode for the machine is set to User Authentication, only the user that is logged in can print.
