Category Top
Settings/Registration and User Privileges
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5R and STMTR Paper
Registering/Editing Custom Paper Types
Registering Paper Frequently Used in the Multi-Purpose Tray
Setting the Method for Selecting Multi-Purpose Tray Paper
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Displaying the IP Address
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Automatic Gradation Adjustment
Correct Density
Correct Shading
Auto Correct Color Mismatch
Making the Color More Vivid When Printing with Full Color
Fine Adjust Zoom
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Adjust Action
Saddle Stitch Staple Repositioning
Saddle Stitch Position Adjustment
Setting the Execution Time for Manual Stapling
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Specifying Paper Drawer Auto Selection Based on Color
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
Setting the Output Trays of Optional Equipment
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Text/Photo Priority in a Black-and-White Original
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Scan Settings
Feeder Jam Recovery Method
Scanning Originals Quietly
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
Image Quality Level for Compact
Settings for Creating Searchable PDF/OOXML
Trace & Smooth Settings
OOXML Settings
Including Background Images When Generating Word Files
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Enabling Auto Collating
Enabling Auto Orientation
Color Mode Settings for Copy
Send
Output Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Scan and Send
Changing the Default Settings for Scan and Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
Displaying a Confirmation Screen When Jobs Are Accepted
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN on Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Autocomplete for E-mail Address Entry
Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for Fax
Registering/Editing/Deleting Sender Names (TTI)
Setting the Authenticated User Name as the Sender Name
Enabling ECM Transmission
Pause Time
Enabling Auto Redial
Checking the Dial Tone before Sending
Fax TX Report
Fax Activity Report
Fax Line Settings
Setting the Line to Use When Sending
Send Start Speed
PIN Code Access
Remote Fax TX Settings
Receive/Forward
Output Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Confirming/Enabling/Deleting Forwarding Settings
Printing Forwarding Settings
Specifying the Fax/I-Fax Inbox Settings
Always Send Notice for RX Errors
Fax Settings
Enabling ECM Reception
Fax RX Report
Confidential Fax Inbox RX Report
Setting the Receive Start Speed
Setting the Receive Password
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Mail Box Settings
Memory Media Settings
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Function Settings » Receive/Forward » Common Settings » Specifying the Fax/I-Fax Inbox Settings
0R9W-0EJ
This section describes various settings, including the Memory Lock mode, for the Memory RX Inbox in the Fax/I-Fax Inbox.
Set/Register Confidential Fax Inboxes
You can set and register a name and PIN for any Confidential Fax Inbox. You can also initialize the registered name and PIN.
Memory RX Inbox PIN
You can set a seven digit PIN for the Memory RX (Receive) Inbox, and restrict its use to only those users who enter the PIN.
Fax Memory Lock
If you set [Use Fax Memory Lock] to 'On' , the machine stores received fax documents in memory without printing them. This is referred to as the Fax Memory Lock.
You can later check the received documents in the Memory RX Inbox, and print or send them as necessary.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
I-Fax Memory Lock
If you set [Use I-Fax Memory Lock] to 'On' , the machine stores received I-fax documents in memory without printing them. This is referred to as the I-Fax Memory Lock.
Memory Lock Start Time
You can set the Memory Lock mode to start automatically at a specified time.
Memory Lock End Time
You can set the Memory Lock mode to end automatically at a specified time.
Divided Data RX Timeout
If it takes longer than the set Divided Data RX Timeout time to receive all the parts of a divided I-fax document, only the data which has been received is combined to form the document.
Data which can be combined to form complete pages is printed, and any remaining data is deleted without being printed.
Press [Function Settings] → [Receive/Forward] → [Common Settings].
Press [Set Fax/I-Fax Inbox].
To set/store a Confidential Fax Inbox:
To set a Memory RX Inbox PIN:
To store received Fax Documents in memory:
To store received I-Fax Documents in memory:
To specify the Memory Lock Start Time settings:
To specify the Memory Lock End Time settings:
To specify the Divided Data RX Timeout settings:
Press [Set/Register Confidential Fax Inboxes].
Press the desired Confidential Fax Inbox number.
If you enter a Confidential Fax Inbox number using - (numeric keys), make sure to enter a two digit number → press [OK].
Specify each setting → press [OK] → [Close].
[Register Box Name]:
Press [Register Box Name] → enter a name → press [OK].
[PIN]:
Press [PIN] → enter up to seven digits for the PIN for the Confidential Fax Inbox using - (numeric keys). Press [Confirm] → enter the PIN again for confirmation → press [OK]. You can leave the PIN blank. You cannot store a PIN with only zeros as the number, such as <0000000>.
[URL Send Settings]:
If you set the machine to send a link via e-mail to the Confidential Fax Inbox in which the document is stored, you can check or perform operations on the document in the Confidential Fax Inbox, using the Remote UI (User Interface) of the machine. If you want to send a link to a Confidential Fax Inbox via e-mail, press [URL Send Settings] → specify the destination → press [OK].
[Initialize]:
To initialize settings, select the Confidential Fax Inbox that you want to initialize → press [Initialize] → [Yes].
Since there is no way to check a stored PIN, make sure that you write down the PIN that you enter, and keep it in a safe place.
Press [Memory RX Inbox PIN].
Press [Set].
Press [PIN] → enter the PIN.
Press [Confirm] → enter the same PIN → press [OK].
Press [OK].
If you do not want to set a PIN for the Memory RX Inbox, press [OK] without entering any numbers.
You cannot store a PIN with only zeros as the number, such as <0000000>. If you enter a number that begins in zeros, such as <02> or <002>, the zeros are ignored and the number is registered as <0000002>, the same as if you had simply entered <2>.
Press [Use Fax Memory Lock].
Press [On] → [OK].
Select [Off] if you do not want to use the Fax Memory Lock.
If the message <Fax Memory RX is On.> does not appear, set [Fax Memory Lock] to 'On' on the Memory RX Inbox screen.
Press [Use I-Fax Memory Lock].
Press [On] → [OK].
Select [Off] if you do not want to use the I-Fax Memory Lock.
If the message <I-Fax Memory RX is On.> does not appear, set [I-Fax Memory Lock] to 'On' on the Memory RX Inbox screen.
Press [Memory Lock Start Time].
Select the conditions.
If you select [Everyday], select a number ([1] to [5]) → enter the start time using - (numeric keys) → press [OK].
You can store up to five different start times.
The time is displayed in 24-hour notation. Enter the time as a four digit number including zeros.
Examples:
7:05 a.m. → 0705
11:18 p.m. → 2318
If you make a mistake when entering the time, enter another four digit number.
If you select [Specify Days], select a day of the week ([Sun] to [Sat]) → select a number ([1] to [5]).
Enter the start time using - (numeric keys) → press [OK].
You can store up to five different start times for each day of the week.
Examples:
7:05 a.m. → 0705
11:18 p.m. → 2318
If you select [Off], press [OK].
If you select [Off], Memory Lock will not automatically turn on at the specified time. You can manually turn Memory Lock On or Off by pressing [On] or [Off] under <Fax Memory Lock> or <I-Fax Memory Lock> on the Memory RX Inbox screen.
You can select [Everyday] for Memory Lock Start Time and [Specify Days] for Memory Lock End Time, and vice versa.
Press [Memory Lock End Time].
If you select [Everyday], select a number ([1] to [5]) → enter the end time using - (numeric keys) → press [OK].
You can store up to five different end times.
Examples:
7:05 a.m. → 0705
11:18 p.m. → 2318
Enter the end time using - (numeric keys) → press [OK].
Examples:
7:05 a.m. → 0705
11:18 p.m. → 2318
The Memory Lock mode will not be turned off automatically. You can manually turn Memory Lock On or Off by pressing [On] or [Off] under <Fax Memory Lock> or <I-Fax Memory Lock> on the Memory RX Inbox screen.
Press [Divided Data RX Timeout].
Press [-] or [+] to adjust the timeout setting → [OK].
If you set the divided data RX timeout time to '0', no divided data RX timeout time is set.
You cannot store any more documents in inboxes in the following cases. (The numbers below may vary depending on the remaining capacity of the hard disk.)
When a total of 2,000 files or images are stored in the Mail Box and Fax/I-Fax Inbox
When a total of 6,000 pages of files or images are stored in the Mail Box and Fax/I-Fax Inbox
If you delete divided data, it cannot be combined to form a complete document, even if the remaining divided data is received later.
Divided data cannot be printed as a regular image unless it has been combined.
If divided data is deleted while you are setting forwarding settings or the Memory Lock mode for the data, all processes regarding the forced printing of the image are canceled.
You can create up to 50 Confidential Fax Inboxes.
The numbers for Confidential Fax Inboxes are 00 to 49.
Setting a name for a Confidential Fax Inbox is optional.
Setting a PIN for a Confidential Fax Inbox is optional.
You can enter up to seven digits for the PIN. If you enter fewer than seven digits, the machine stores the PIN with leading zeros.
Example: If <321> is entered, <0000321> is stored.
If the fax board is installed, you can receive faxes into memory.
