Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Specifying the Orientation of the Original Image
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Available Paper Sizes
0C1Y-0X4
When received documents are printed, they are printed from the paper drawer that has the same paper size as the received document.
If paper of the correct size is not available, the machine automatically selects a different paper size in the following order. The paper size is automatically selected in the same order, even if paper runs out while printing.
Available Paper Sizes for Received Documents
Size of Received Document
Paper Size Priority
11" x 17"
LTR* → LGL* → STMT x 2
LGL
LTR x 2 → STMT x 2
LTR
LTR → LGL → STMT x 2
STMT
STMT → LTR → LGL
* Received documents are automatically reduced before being printed on the paper size indicated.
Received documents can be printed on the following paper sizes and paper types:
Size: LGL, LTR, or STMT
Paper Types: plain, recycled, color, or custom paper type (paper with the following settings; Basis Weight: 17 to 28 lb bond (64 to 105 g/m2), Type: Normal, Finish: Uncoated or Recycled)
You can set the machine to reduce received documents in 1% increments between 75% to 97% if the document is larger than any of the available paper sizes. (See "Reducing a Received File.")
You can set the machine to print received documents on both sides of the paper. (See "2-Sided Printing.")
