[JPEG]:
Sends the file in the JPEG format, if you select a color mode other than Black-and-White.
[TIFF]:
Sends the file in the TIFF format, if you select a color mode other than Black-and-White.
[PDF]:
Sends the file in the PDF file format, regardless of the color mode. You can also specify additional settings.
[XPS]:
Sends the file in the XPS file format, regardless of the color mode. You can also specify additional settings.
[OOXML]:
Sends the file in the Office Open XML (pptx) format only if you select the Full Color mode or the Grayscale mode for the color mode.
If you send the file stored in the Memory RX Inbox, you cannot select OOXML as the file format.
You can select additional settings if you send in the PDF, XPS or OOXML format. Refer to the following for instructions on setting each type of PDF, XPS, or OOXML:
[Trace & Smooth]: Trace and Smooth
[Compact]: Compact PDF or XPS
[OCR (Text Searchable)]: Searchable PDF/XPS/OOXML
[Add Digital Signatures]: Adding a Digital Signature to a PDF or XPS
[Encrypt]: Encrypting PDF Files
[Apply Policy]: Applying a Policy
To view a JPEG file, software that supports the JPEG format (such as Microsoft Internet Explorer for Windows) is required.
To view a TIFF file, software that supports the TIFF format (such as Imaging for Windows) is required.
To view a PDF file or to search a text in a PDF file, software that supports the PDF format (such as Adobe Reader/Adobe Acrobat) is required.
To view an XPS file or to search a text in an XPS file, software that supports the XPS format (such as XPS Document Viewer) is required.
To view an OOXML file or to search a text in an OOXML file, software that supports the OOXML format (Microsoft Office PowerPoint 2007/2010) is required.
