Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Specifying the Orientation of the Original Image
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying Destinations » Setting Your Personal Folder as the Destination
0C1Y-0U2
A personal folder can be set for each authenticated user. You can specify your own folder as the destination.
A personal folder is enabled only if you are managing users by login service, such as SSO-H.
For information on how to specify a personal folder, see "Specifying Personal Folders."
Press [Scan and Send] → [Personal Folder].
If you are using a login service, it is necessary to log in to the machine with the appropriate procedure for the login service. To use SSO-H as the login service, see "Login Service."
If the screen for registering a personal folder is displayed after pressing [Personal Folder], you need to specify each item on the screen. For more information on each setting item, see "Specifying a File Server Using the Keyboard."
To verify/change the path of the personal folder or the authentication information, press  on the top right of the screen → [Register/Edit Info. for Each User] → [Personal Folder]
The administrator can limit the destination for file transmission to each personal folder of the general user. (See "Restricting Destination for File Transmission.")
