Registering an Advanced Box Address
A folder in the Advanced Box of another imageRUNNER ADVANCE series machine which is opened as an SMB or WebDAV server can be registered as a destination in the Address Book.
For more information on Advanced Boxes, see user manuals for other imageRUNNER ADVANCE series machines with Advanced Boxes.
Press [Scan and Send] → [Address Book].
Press [Other Ops.].
Press [Register/Edit].
4.
Press [Register New Dest.].
5.
Press [File].
6.
Select an address list from Address List 1 to 10.
Address lists are a convenient way to classify destinations.
7.
Press [Name].
8.
Enter a name for the file server → press [OK].
The first character that you enter for the name is used for sorting the destination list when you press keys, such as [ABC], [DEF], and [GHI], on the Address Book screen. If [Search by Name] is pressed on the Address Book screen, a screen for narrowing the search in the Address Book appears.
9.
Press [Next].
10.
Select the protocol from the <Protocol:> drop-down list.
Select [Windows (SMB)] or [WebDAV].
To save files in the Advanced Box of another imageRUNNER ADVANCE series machine with an imagePASS attached, select [WebDAV]. (Windows (SMB) cannot be used.)
11.
Specify each setting.
For details on the settings, see step 4 of
"Storing in an Advanced Box."
If you try to send a document to an Advanced Box for which [Confirm Before Sending] is set to 'On', a screen prompting you to enter the password appears each time.
If you want to register an Advanced Box in a group address, set [Confirm Before Sending] to 'Off'. You cannot send to a group address including an Advanced Box for which [Confirm Before Sending] is set to 'On'.
If you specify the destination that you set to 'On' for [Confirm Before Sending] as the forwarding destination, the screen to enter the password does not appear. The registered password is used and forwarding is performed.
12.
Press [OK].
If you are managing Address Book access numbers, perform the procedure in step 13 of
"Registering an E-Mail Address."
13.
Press [Close] → [OK].
If you set [Language/Keyboard Switch On/Off] to 'On', the host name and folder path of the file server destination may not appear correctly, and you may not be able to browse them.
