Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Specifying the Orientation of the Original Image
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Specifying the Orientation of the Original Image
0C1Y-0WR
You can specify the orientation of an original placed on the platen glass or into the feeder as vertical or horizontal.
By properly specifying the orientation of the original, the recipient can receive properly oriented data.
Press [Scan and Send].
Specify the destination → press [Options] → [Orig. Content Orientation].
Select the image orientation → press [OK] → [Close].
The orientation types of originals are as follows:
Portrait:
Portrait refers to an original in vertical orientation: the shorter edges are at the top and bottom of the original.
Landscape:
Landscape refers to an original in horizontal orientation: the shorter edges are at the left and right of the original.
Place the original as follows:
For Originals in Portrait Orientation
Type of Original
Platen Glass
Feeder
For Originals in Landscape Orientation
Type of Original
Platen Glass
Feeder
