Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Specifying the Orientation of the Original Image
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Preview
Preview
0C1Y-0WA
This mode enables you to preview the scanned data of your originals, and to check the page count before sending your document.
Press [Scan and Send].
Specify the destination → press [Options] → [Preview].
Press [Close].
4.
Press (Start).
5.
Press [Start Sending].
6.
Press or to select the page that you want to check.
You can press (reduce) or (enlarge) to zoom in or out.
You can press , , , or to specify the area to display when you zoom in or out on the page.
You can also delete scanned pages as necessary.
If you want to delete a single page:
If you want to delete multiple consecutive pages:
Press [Delete Pages] → [Single Page].
Press [-] or [+] to select the page you want to delete.
Press [Start Deleting] → [Yes].
Press [Delete Pages] → [Multiple Pages].
Press [First Page] → press [-] or [+] to select the first page of the range to delete.
Press [Last Page] → press [-] or [+] to select the last page of the range to delete.
7.
