Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Specifying the Orientation of the Original Image
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Storing New Addresses » Storing/Editing/Deleting One-Touch Buttons
0C1Y-0UJ
You cannot register new destinations in a group destination that is stored in a one-touch button. The destinations must be registered in the one-touch buttons beforehand.
Storing/Editing One-Touch Buttons
Press [Scan and Send] → [One-Touch].
Press [Register]→ select a one-touch button to store or change → press [Register/Edit].
If you know the three digit number for the one-touch button, you can press → enter the three digit number of the desired one-touch button using - (numeric keys).
If you select a one-touch button in which a destination is already stored, proceed to step 3.
The following icons are displayed to indicate the stored destination type for one-touch buttons in which a destination is already stored:
(E-Mail)
(Fax)
(I-Fax)
(File server)
(Group)
Select the type of destination to register.
For instructions on registering a fax number in a one-touch button, see "Storing New Addresses."
If you select [E-Mail]:
If you select [I-Fax]:
If you select [File]:
If you select [Group]:
If you select [Register from LDAP Server]:
Press [E-Mail].
Enter a name for the address [Name] in accordance with steps 7 and 8 of "Registering an E-Mail Address."
Press [One-Touch Name].
Enter a name → press [OK].
Press [Next].
Press [E-Mail Address].
Enter the e-mail address → press [OK].
Select one of the following for <Divide Data> as necessary → press [OK].
For details on Divide Data, see step 4 of "Specifying a Destination by Entering an E-mail Address."
Press [I-Fax].
Enter a name for the address [Name] in accordance with steps 7 and 8 of "Registering an I-Fax Address."
Press [Next].
Specify the I-fax address in accordance with steps 10 to 16 of "Registering an I-Fax Address."
Press [File].
Enter a name for the address [Name] in accordance with steps 7 and 8 of "Registering a File Server Address."
Press [Next].
Specify the file server address in accordance with steps 10 to 19 of "Registering a File Server Address."
Press [Group].
Enter a name for the address [Name] in accordance with steps 7 and 8 of "Registering a Group Address."
Press [Next].
Press [Add from One-Touch] → select a destination to store in the group address → press [OK].
You can only select destinations that are already stored in one-touch buttons to be part of a one-touch button group address.
If you know the three digit number for the desired one-touch button, you can press → enter the three digit number of the desired one-touch button using - (numeric keys).
Press [OK].
Press [Register from LDAP Server].
Specify the address by using LDAP server in accordance with steps 4 to 9 of "Specifying Destinations Using the Address Book (LDAP Server)."
Select the destination from the search results → press [Next].
You cannot select multiple destinations at the same time.
To cancel a specified destination, select the destination you want to register again.
The information that can be obtained via the LDAP server consists of only names, e-mail addresses, and fax numbers.
Press [OK].
4.
Press [Close] → [OK].
Press [Register] → select the one-touch button to delete → press [Delete].
(E-Mail)
(Fax)
(I-Fax)
(File server)
(Group)
Press [Yes].
4.
If you set [Language/Keyboard Switch On/Off] to 'On', the host name and folder path of the file server destination may not appear correctly, and you may not be able to browse them. (See "Enabling the Language/Keyboard Switch.")
Destinations stored in one-touch buttons also appear in the Local Address Book.
For instructions on registering/editing a fax number, see "Storing New Addresses."
