Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Specifying the Orientation of the Original Image
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Applying a Policy
Applying a Policy
0C1Y-0W9
You can send a PDF compatible with Rights Management Server. The permission to access the stored PDF can be edited with the Adobe LiveCycle Rights Management ES.
You cannot set [Apply Policy] in combination with the following conditions:
When the Encrypt mode is set
When [Format PDF to PDF/A] is set to 'On' (See "Formatting PDF Files to PDF/A.")
Adobe LiveCycle Rights Management ES or Adobe LiveCycle Rights Management ES2 is required to use [Apply Policy]. For more information, contact your local authorized Canon dealer.
The following conditions must be met to use [Apply Policy]:
The Adobe LiveCycle Rights Management server and the machine are connected via the Internet or an intranet.
The URL for the Adobe LiveCycle Rights Management server is set in [Rights Management Server Settings]. (See "Setting a Rights Management Server.")
Press [Scan and Send] → specify the destination → press the file format button.
Select [PDF] → press [Set Details].
Press [Apply Policy] → Enter the user name and password → press [OK].
Depending on the authentication method you use, the screen to enter the password may not appear.
For a login user name and password for access to Rights Management Server, contact your system manager.
4.
Select the policy to apply → press [OK].
The policies registered in the Adobe LiveCycle Rights Management server are displayed in the policy list.
A maximum of 64 policies can be displayed.
With this machine, only policies encrypted with AES 128-bit or AES 256-bit can be applied.
