The maximum size of an image that you can send at 600 x 600 dpi resolution is LTR. If the image exceeds this size, it may be cut off.
When using a resolution of 200 x 400 dpi, 400 x 400 dpi, and 600 x 600 dpi, you can only send using [Black & White].
If [OOXML] is selected as the file format, you can only send in [300x300 dpi] or [600x600 dpi].
