Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in an Advanced Box
Setting Your Personal Folder as the Destination
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS/OOXML
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Applying a Policy
Preview
2-Sided Original
Adjusting Density Manually
Adjusting Background Density
Selecting the Original Type
Adjusting the Image Sharpness
Erase Frame
Delayed Send
Specifying the Orientation of the Original Image
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Top » Scan and Send » Receiving I-Fax Documents » Receiving Documents
Receiving Documents
0C1Y-0X1
When documents are being received, the Processing/Data indicator on the control panel flashes a green light.
When document reception is complete, the Processing/Data indicator on the control panel maintains a steady green light. This indicates that documents are stored in memory.
The Processing/Data indicator flashes or maintains a steady green light even when the machine enters the Sleep mode.
The Error indicator flashes a red light when either the amount of available memory is low, or paper needs to be loaded into a paper drawer.
The document is printed.
The Processing/Data indicator goes out when documents stored in memory are printed.
If there is no paper on which the received documents can be printed, the received documents are stored in memory.
The memory can hold a total of 6,000 pages of sent and received documents.
Documents which have been stored in memory because the paper has run out are automatically printed when paper is loaded into a paper drawer.
