] or [
] and press [OK].
] (Start).
When scanning from the feeder, or set the <File Format> to <JPEG>
After scanning the document, the scanned data is sent to the USB memory.
When scanning from the platen glass, or set <File Format> to other than <JPEG>
Proceed to Step 7
] (Start).
(1)
Select <Cancel> with [
] or [ ], and then press [OK]. |
(2)
Select <Yes> with [
] or [
Folder name
The "SCAN_00" folder is created in the top level directory (root folder) in the USB memory device. Scanned document files are saved in this folder.
When the "SCAN_00" folder reaches limit, the "SCAN_01" folder is automatically created. Folders up to "SCAN_99" are automatically created when the current working folder becomes full.
File name
File names between "SCAN0001.XXX" and "SCAN9999.XXX" are provided. ("XXX" is the extension for the file format.)
The two-digit folder number is provided in the fifth and sixth characters from the left.
A maximum of 100 files can be saved in a folder.
