Category
Top » Scanning » Saving Scanned Documents to USB Memory Device » Changing the Default Scan Settings for Saving to USB Memory Device
Category Top
Scanning Paper Documents and Saving Them to a Computer (USB & Network Connection)
Preparing to Scan Your Document (Saving to a Computer)
System Requirements (Scan)
Registering the Scanner in MF Network Scan Utility
Basic Scan Flow (Saving to a Computer)
Scanning Using Keys on the Operation Panel
Performing a Scan Using a Shortcut Key
Scanning with the MF Toolbox
Scanning an Image from an Application
Scanning Using the WIA Driver (Windows XP/Vista/7 Only)
Attention (WIA Driver)
[New Scan] Dialog Box
Using the MF Toolbox
Creating One PDF File from Two or More Pages
Using the ScanGear MF
Using the Simple Mode
Using the Advanced Mode
Creating a Cropping Frame
Determining Resolution
Before Using USB Memory Device
Basic Scan Flow (Saving to USB Memory Device)
Changing the Scan Settings (Saving to USB Memory Device)
Attention (Changing the Scan Settings (Saving to USB Memory Device))
E-mailing Scanned Documents
Preparing to Use the E-mail Functions
Scanning Fundamentals (E-mail)
Specifying Destinations (E-mail)
Changing the Scan Settings (E-mail)
E-mail Settings
Checking/Canceling Send Data (E-mail)
Registering the E-mail Sender Name
Changing the Default Scan Settings for Sending to E-mail
Sending Scanned Documents to a File Server
Preparation for Scanning (File Server)
Scanning Fundamentals (File Server)
Specifying the Destination (File Server)
Changing the Scan Settings (File Server)
Checking/Canceling Send Data (File Server)
Changing the Default Settings for Sending to a File Server
Collapse all|Expand all
07K4-0EU
Default settings are the settings that are automatically applied to all tasks when the power is turned ON or [] (Reset) is pressed. You can modify these settings based on your needs.
You can change the following default settings based on your needs.
Scan size
Color Mode
File Format
Density
Original orientation
Original Type
2-Sided Original
Sharpness
Data Size
1
Press [] (Menu).
2
Select <Scan Settings> using [] or [] and press [OK].
3
Select <Memory Media Settings> using [] or [] and press [OK].
4
Make sure that <Change Defaults> is selected and press [OK].
5
Select the item using [] or [] and press [OK].
For details about settings, see "Changing the Scan Settings (Saving to USB Memory Device)."
6
Select <Apply> using [] or [] after you have specified the setting and press [OK].
7
Press [] (Menu) to close the menu screen.
