Platen Glass
Feeder
Type
Plain paper
Heavy paper
Photograph
Small documents (for example, index cards)
Special types of paper (for example, tracing paper, transparencies, etc.)*1
Booklet (Up to 7/8" (20 mm) thickness)
Plain paper
(Multi-page documents of the same size, thickness and weight/one-page documents)
Size (W x L)
Up to 8 1/2" x 11 5/8" (216 mm x 297 mm)
Maximum size: 8 1/2" x 14" (215.9 mm x 355.6 mm)
Minimum size: 5 1/2" x 5" (139.7 mm x 128 mm)
Weight
Up to 4.4 lb (2 kg)
One-sided scanning (1 page): 13 to 28 lb Bond (50 to 105 g/m²)
Two-sided scanning: 17 to 28 lb Bond (64 to 105 g/m²)
Paper Capacity
1 sheet
Up to 50 sheets (Letter)*2
Up to 30 sheets (Legal)*2 |
*1
To copy transparent documents (for example, tracing paper or transparencies), make sure to place the documents face down on the platen glass and cover them with plain white paper.
*2
22 lb Bond (80 g/m²)
To place your document
Make sure any glue, ink, or correction fluid on the document is completely dry before placing it on the platen glass or into the feeder.
To prevent paper jams in the feeder
Do not use any of the following.
Wrinkled or creased paper
Carbon paper or carbon-backed paper
Curled or rolled paper
Coated paper
Torn paper
Onion skin or thin paper
Stapled or clipped documents
Paper printed by a thermal transfer printer
Transparencies
