Before changing the scan settings, see "Attention (Changing the Scan Settings (Saving to USB Memory Device))."
For instructions on how to save scanned documents to USB memory device, see "Basic Scan Flow (Saving to USB Memory Device)."
<Color>
Select when scanning documents in color.
<B&W>
Select when scanning documents in black and white.
<PDF (Compact)>
Saves the file in PDF format. Color images such as photos or illustrations are compressed more than in <PDF>, reducing the file size.
<PDF>
<JPEG>
Saves the file in JPEG format.
<TIFF>
Saves the file in TIFF format.
Decrease the density.
Increase the density.
<Portrait>
Specify when the document is in portrait orientation.
<Landscape>
Specify when the document is in landscape orientation.
<Text>
Best suited for scanning documents that contain text only or handwritten text and drawings. Blueprints and very weak pencil manuscripts can be clearly captured.
<Text/Photo>
Best suited for scanning documents that contain text, drawings, and photos.
<Photo>
Best suited for scanning documents that contain printed halftone photos.
<Off>
Booklet setting for 2-sided documents is not set.
<Book Type>
Select when the orientation (top-to-bottom) of the images on the front and back sides is the same.
<Calendar Type>
Select when the orientation (top-to-bottom) of the images on the front and back sides is different.
To clearly capture halftone photos, adjust this setting to the appropriate level on the <-> scale. This can counteract the effect of moiré patterns (uneven gradation and striped patterns).
To clearly capture text or lines, adjust this setting to the appropriate level on the <+> scale. It is best suited for scanning blueprints and very weak pencil manuscripts.
<Small: Memory Priority>
Only a small amount of memory is required, but low-quality scans are produced.
<Standard>
The amount of memory required and resultant scan quality are somewhere in the middle between <Small: Memory Priority> and <Large: Image Quality Priority>.
A large amount of memory is required, but high-quality scans are produced.
] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] (Menu) to close the menu screen.
] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
<Data Size Priority>
<Normal>
The amount of memory required and resultant scan quality are somewhere in the middle between <Data Size Priority> and <Image Quality Priority>.
