For instructions on how to send e-mail, see "Scanning Fundamentals (E-mail)."
<Color>
Select when scanning documents in color.
<B&W>
Select when scanning documents in black and white.
<PDF (Compact)>
Saves the file in PDF format. Color images such as photos or illustrations are compressed more than in <PDF>, reducing the file size.
<PDF>
Decrease the density.
Increase the density.
<Portrait>
Specify when the document is in portrait orientation.
<Landscape>
Specify when the document is in landscape orientation.
<Text>
Best suited for scanning documents that contain text only or handwritten text and drawings. Blueprints and very weak pencil manuscripts can be clearly captured.
<Text/Photo>
Best suited for scanning documents that contain text, drawings, and photos.
<Photo>
Best suited for scanning documents that contain printed halftone photos.
<Off>
Booklet setting for 2-sided documents is not set.
<Book Type>
Select when the orientation (top-to-bottom) of the images on the front and back sides is the same.
<Calendar Type>
Select when the orientation (top-to-bottom) of the images on the front and back sides is different.
To clearly capture halftone photos, adjust this setting to the appropriate level on the <-> scale. This can counteract the effect of moiré patterns (uneven gradation and striped patterns).
To clearly capture text or lines, adjust this setting to the appropriate level on the <+> scale. It is best suited for scanning blueprints and very weak pencil manuscripts.
<Small: Memory Priority>
Only a small amount of memory is required, but low-quality scans are produced.
<Standard>
The amount of memory required and resultant scan quality are somewhere in the middle between <Small: Memory Priority> and <Large: Image Quality Priority>.
A large amount of memory is required, but high-quality scans are produced.
] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] (Menu) to close the menu screen.
] (Menu).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
<Data Size Priority>
<Normal>
The amount of memory required and resultant scan quality are somewhere in the middle between <Data Size Priority> and <Image Quality Priority>.
