Category
Top » Scanning » Scanning Paper Documents and Saving Them to a Computer (USB & Network Connection) » Creating One PDF File from Two or More Pages
Category Top
Preparing to Scan Your Document (Saving to a Computer)
System Requirements (Scan)
Registering the Scanner in MF Network Scan Utility
Basic Scan Flow (Saving to a Computer)
Scanning Using Keys on the Operation Panel
Performing a Scan Using a Shortcut Key
Scanning with the MF Toolbox
Scanning an Image from an Application
Scanning Using the WIA Driver (Windows XP/Vista/7 Only)
Attention (WIA Driver)
[New Scan] Dialog Box
Using the MF Toolbox
Using the ScanGear MF
Using the Simple Mode
Using the Advanced Mode
Creating a Cropping Frame
Determining Resolution
Saving Scanned Documents to USB Memory Device
Before Using USB Memory Device
Basic Scan Flow (Saving to USB Memory Device)
Changing the Scan Settings (Saving to USB Memory Device)
Attention (Changing the Scan Settings (Saving to USB Memory Device))
Changing the Default Scan Settings for Saving to USB Memory Device
E-mailing Scanned Documents
Preparing to Use the E-mail Functions
Scanning Fundamentals (E-mail)
Specifying Destinations (E-mail)
Changing the Scan Settings (E-mail)
E-mail Settings
Checking/Canceling Send Data (E-mail)
Registering the E-mail Sender Name
Changing the Default Scan Settings for Sending to E-mail
Sending Scanned Documents to a File Server
Preparation for Scanning (File Server)
Scanning Fundamentals (File Server)
Specifying the Destination (File Server)
Changing the Scan Settings (File Server)
Checking/Canceling Send Data (File Server)
Changing the Default Settings for Sending to a File Server
Collapse all|Expand all
07K4-0E9
1
Place documents on.
2
Press [].
3
Select <Remote Scanner> using [] or [] and press [OK].
The machine is now waiting to be scanned.
4
Double-click the [Canon MF Toolbox 4.9] icon on the desktop.
The MF Toolbox starts.
5
Press the button other than [OCR].
6
Select [PDF] or [PDF (Multiple Pages)] in [Save as Type].
7
Specify the required settings as needed and click [PDF Settings].
The [PDF Settings] dialog box appears.
8
Specify the required settings as needed and click [OK].
[Create Searchable PDF]
Converts the characters in the document to text data and makes the PDF document searchable with keywords.
[Text Language]
Select the language of the text to be scanned. The characters may be recognized more accurately if you select [English] from the drop-down list and set [Image Quality] to [300 dpi] or higher in [Scanner Settings].
[PDF Compression]
Select [High] for color images such as photos or illustrations to reduce file sizes.
9
Click [Start].
When setting documents on the platen glass
(1)
Place the next page and click [Next].
(2)
When scanning is complete, click [Finish].
