Category
Top » Scanning » Scanning Paper Documents and Saving Them to a Computer (USB & Network Connection) » Basic Scan Flow (Saving to a Computer)
Category Top
Preparing to Scan Your Document (Saving to a Computer)
System Requirements (Scan)
Registering the Scanner in MF Network Scan Utility
Scanning Using Keys on the Operation Panel
Performing a Scan Using a Shortcut Key
Scanning with the MF Toolbox
Scanning an Image from an Application
Scanning Using the WIA Driver (Windows XP/Vista/7 Only)
Attention (WIA Driver)
[New Scan] Dialog Box
Using the MF Toolbox
Creating One PDF File from Two or More Pages
Using the ScanGear MF
Using the Simple Mode
Using the Advanced Mode
Creating a Cropping Frame
Determining Resolution
Saving Scanned Documents to USB Memory Device
Before Using USB Memory Device
Basic Scan Flow (Saving to USB Memory Device)
Changing the Scan Settings (Saving to USB Memory Device)
Attention (Changing the Scan Settings (Saving to USB Memory Device))
Changing the Default Scan Settings for Saving to USB Memory Device
E-mailing Scanned Documents
Preparing to Use the E-mail Functions
Scanning Fundamentals (E-mail)
Specifying Destinations (E-mail)
Changing the Scan Settings (E-mail)
E-mail Settings
Checking/Canceling Send Data (E-mail)
Registering the E-mail Sender Name
Changing the Default Scan Settings for Sending to E-mail
Sending Scanned Documents to a File Server
Preparation for Scanning (File Server)
Scanning Fundamentals (File Server)
Specifying the Destination (File Server)
Changing the Scan Settings (File Server)
Checking/Canceling Send Data (File Server)
Changing the Default Settings for Sending to a File Server
Collapse all|Expand all
07K4-0E0
For better scanning results
We recommend to scan documents on the platen glass when using the feeder may not produce the desired amount of clarity.
There are four main scanning procedures.
Scanning can be performed using keys on the operation panel. This allows you to scan easily using the existing settings.
Scanning can be performed by operating the supplied software. This allows you to scan according to your purpose with the detailed settings.
Scanning can be performed using your application. This allows you to open the scanned data as is in your application.
Scanning can be performed using the driver system supplied with Windows operating systems.
