] (Menu).
]or [
] and press [OK].
] or [
] and press [OK].
(1)
Select <Register> using [
] or [ ] and press [OK]. ![]() |
(2)
Select the shortcut key that you want to register using [
] or [ ] and press [OK].![]() |
(3)
Select the connection method, using [
(4)
Select the destination using [
] or [ ] and press [OK].When one computer is connected to the machine via a USB cable:
This screen is not displayed. When more than ten computers are connected to the machine simultaneously.
Up to ten computers can be displayed as a list of computers connected to the machine. (Scanning cannot be performed otherwise). Reduce the number of computers connected to the machine over the network.
(5)
Specify the scan settings using [
] or [ ]and press [OK].![]()
(1)
Select <Confirm Destination> using [
(2)
Select the destination that you want to confirm using [
] (Menu) to close the menu screen.|
When scanning from the operation panel
You cannot scan more than one document at a time.
] (Shortcut Scan) into which the destination that you want to select is registered.
When scanning cannot be performedYou cannot perform a scan while the MF Toolbox setup screen is displayed.
Click [
] to close the screen before starting a scan.![]() |
To specify a location where the scanned images are saved:
Once scanning is complete, a folder is automatically displayed to which the scanned images are saved. By default, a folder bearing the scanning date is created inside the [My Pictures] folder in [My Documents]. (On Windows Vista/Windows 7, the folder is created in the [Pictures] folder.)
To change the scan settings:
You can re-specify the save location, file format, resolution, and other settings from a computer.
See "Using the MF Toolbox" for more information.
