To scan using the shortcut keys
When using the shortcut keys which are registered destinations etc., you can send the documents by scanning with one-touch. For details on how to register or send, see "Performing a Scan Using a Shortcut Key."
] or [
] and press [OK].
] or [
] and press [OK].
"Registering the Scanner in MF Network Scan Utility"
You can change the names for the displayed computers.
] or [
] and press [OK].
Scan Mode
Resolution
File Type
PDF Settings
Color Scan
Color
300 dpi
PDF
Searchable/Compact
B&W Scan
Black and White
300 dpi
TIFF
Custom 1
Color
300 dpi
JPEG/Exif
Custom 2
Color
300 dpi
PDF
Searchable/Standard
If you cannot scan |
You cannot scan when MF Toolbox setting screen is displayed.
Click [
] to close the screen before starting a scan.![]() |
Scanning from the feeder
After saving the document, the display returns to the basic scanning screen.
Scanning from the platen glass
Proceed to Step 6
] or [
], and then press [OK].
(1)
Select <Cancel> with [
] or [ ], and then press [OK]. |
(2)
Select <Yes> with [
(1)
Select <Confirm Destination> with [
] or [
The location of saved scanned images
After scanning, the folder where the images have been saved to opens automatically.
By default, the folder for the date when you scanned the data is created in the [Pictures] folder in [My Documents]. (For Windows XP, the folder is created in the [My Pictures] folder.)
To change the scanner settings
From your computer you can change the settings for the save location, file format, and image resolution.
For details on the setting procedure, see "Using the MF Toolbox."
