Category
Top » Scanning » E-mailing Scanned Documents » Scanning Fundamentals (E-mail)
Category Top
Scanning Paper Documents and Saving Them to a Computer (USB & Network Connection)
Preparing to Scan Your Document (Saving to a Computer)
System Requirements (Scan)
Registering the Scanner in MF Network Scan Utility
Basic Scan Flow (Saving to a Computer)
Scanning Using Keys on the Operation Panel
Performing a Scan Using a Shortcut Key
Scanning with the MF Toolbox
Scanning an Image from an Application
Scanning Using the WIA Driver (Windows XP/Vista/7 Only)
Attention (WIA Driver)
[New Scan] Dialog Box
Using the MF Toolbox
Creating One PDF File from Two or More Pages
Using the ScanGear MF
Using the Simple Mode
Using the Advanced Mode
Creating a Cropping Frame
Determining Resolution
Saving Scanned Documents to USB Memory Device
Before Using USB Memory Device
Basic Scan Flow (Saving to USB Memory Device)
Changing the Scan Settings (Saving to USB Memory Device)
Attention (Changing the Scan Settings (Saving to USB Memory Device))
Changing the Default Scan Settings for Saving to USB Memory Device
Preparing to Use the E-mail Functions
Specifying Destinations (E-mail)
Changing the Scan Settings (E-mail)
E-mail Settings
Checking/Canceling Send Data (E-mail)
Registering the E-mail Sender Name
Changing the Default Scan Settings for Sending to E-mail
Sending Scanned Documents to a File Server
Preparation for Scanning (File Server)
Scanning Fundamentals (File Server)
Specifying the Destination (File Server)
Changing the Scan Settings (File Server)
Checking/Canceling Send Data (File Server)
Changing the Default Settings for Sending to a File Server
Collapse all|Expand all
07K4-0EY
Attach scanned documents to e-mails and send them to a specified destination.
This section describes the basic procedure.
1
Place documents.
2
Press [].
3
Select <E-Mail> using [] or [] and press [OK].
4
Specify the destination.
Specify destinations in the following ways.
input directly
by selecting a one-touch key
by selecting a coded dial code
from the Address book
under sequential broadcasting
5
Specify the scan settings based on your purpose of the scan.
The following settings can be changed.
Scan size
Color Mode
File Format
Density
Original orientation
Original Type
2-Sided Original
Sharpness
Data Size
The settings specified here are effective only for the current task. To make the settings effective for all e-mail send operations, see "Changing the Default Scan Settings for Sending to E-mail."
6
Specify the e-mail settings as needed.
Subject/Body
Reply-to
Priority
7
Press [] (Start).
Scanning starts.
8
To continuously scan the document, press [] (Start).
To Cancel the scan
(1)
Select <Cancel> with [] or [], and then press [OK].
(2)
Select <Yes> with [] or [], and then press [OK].
To confirm the destination
(1)
Select <Destinations: > with [] or [], and then press [OK].
To confirm the number of transferred pages
(1)
Select <No. of TX Pages> with [] or [], and then press [OK].
9
Select <Start Sending> with [] or [], and then press [OK].
The E-mail is sent.
