Category
Top » Scan and Send » Reader Extensions
Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Collapse all|Expand all
Reader Extensions
The Reader Extensions mode enables you to add comments, etc. when using the Adobe Reader software distributed for the viewing of PDF files.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Reader Extensions is only compatible with Adobe Reader 7 or later.
Press [Scan and Send] → specify the destination → press the file format button.
Select [PDF] → press [Set Details].
If [Set Details] is not displayed, press [Reader Extensions] on the <File Format> screen.
Press [Reader Extensions] → [OK] → [OK].
If both Reader Extensions and [Password Required to Change Permiss.] for Encrypted PDF are set, Reader Extensions functions are restricted to the set privileges.
You cannot set Reader Extensions in the following cases:
If [Optimize PDF for Web] is set to 'On', and the Digital Signatures mode is set
If [Format PDF to PDF/A] is set to 'On' (See "Formatting PDF Files to PDF/A.")
If Digital Signature and Reader Extensions are both set for a PDF file, changes made after the signature is applied are stored as Comments in the PDF file.
If you are setting both Reader Extensions and Encrypted PDF, and specifying [Password Required to Change Permiss.] for Encrypted PDF, select one of the following from the Allow Changes drop-down list.
Signature Field Signing
Commenting and Signature Field Signing
Changes but Add Comments/Extract Pages
Changes but Extract Pages
When opening a PDF with Reader Extensions using Adobe Reader, an error will occur if the creation time of a PDF file is later than the time on the computer clock. Errors may occur if the time settings on the machine clock and the computer clock differ.
The following features are available in Adobe Reader 7 or later for Reader Extensions compatible PDF files:
Edit Comments
Store Corrected Files (Save or Save As)
The following features are available in Adobe Reader 9 or later for Reader Extensions compatible PDF files:
Add Digital Signatures
