[Send to Myself] appears only if you register a user's e-mail address when you are using authentication by SSO-H.
If you set the Local Device Authentication system of SSO-H as the login service, your e-mail address as registered in the Local Device Authentication system of SSO-H is set as the destination.
If you set the Domain Authentication user authentication system of SSO-H as the login service (including when performing Domain Authentication with the 'Domain Authentication + Local Device Authentication' user authentication system), the e-mail address registered for Active Directory or the imageWARE Accounting Manager is set.
If you set to perform authentication by SSO-H, appropriate operations for each authentication are needed. If you are performing user authentication using the SSO-H login service, see "Login Service."
