Function
Optional Product Required
Notes
Feeding Envelopes from Paper Source
Envelope Feeder Attachment-D1
The Envelope Feeder Attachment-D1 can only be attached to Paper Drawer 2.
Auto Document Feed/Scanning 2- Sided Originals Automatically Finished Stamp
DADF-AG1
If you are using the imageRUNNER ADVANCE 4051/4045, the DADF-AG1 is standard-equipped.
Adding Paper Sources
Cassette Feeding Unit-AF1
Adding High Capacity Feeding Area
Paper Deck Unit-B2
Collate/Group/Offset/Staple
Restrictions for the Above Modes/Offset Jobs
Inner Finisher-D1
The Inner Finisher-D1 cannot be used with the Inner 2Way Tray-H1, Staple Finisher-G1, or Booklet Finisher-G1.
Staple Finisher-G1 or Booklet Finisher-G1
Buffer Pass Unit-H1
The Staple Finisher-G1 or Booklet Finisher-G1 cannot be used with the Inner 2Way Tray-H1 or Staple Finisher-G1.
Saddle Stitch Booklet
Booklet Finisher-G1
Buffer Pass Unit-H1
The Booklet Finisher-G1 cannot be used with the Inner Finisher-D1 or 2Way Tray-H1.
Hole Punch
Inner 2/3 Hole Puncher-A1
Inner Finisher-D1
External 2/3 Hole Puncher-B2
Buffer Pass Unit-H1, Staple Finisher-G1, or Booklet Finisher-G1
Additional Output Tray for the Inner Finisher
Inner Finisher Additional Tray-A1
Inner Finisher-D1
Additional Output Tray under the Scanner Unit/Collate/Group/Rotate 90 Degrees
Inner 2Way Tray-H1
The Inner 2Way Tray-H1
cannot be used with the Inner Finisher-D1, Staple Finisher-G1, or Booklet Finisher-G1. |
Department ID Management Using Card
Copy Card Reader-F1
Additional USB Port
USB Device Port-D1
Multimedia Reader/Writer
Multimedia Reader/Writer-A2
USB Device Port-D1
Function
Notes
PCL Print
PCL Printer Kit
PS Print
PS Printer Kit
Direct Print (for PDF)/Printing PDF files stored in memory media, the Advanced Box, or the Advanced Box of another imageRUNNER ADVANCE machine on the network
PS Printer Kit or Direct Print Kit (for PDF/XPS)
Direct Print (for XPS)
Barcode Printing
Barcode Printing Kit
PCL Printer Kit
Wireless LAN Connection
Wireless LAN Board
Expansion Bus
Fax Function
Display Fax Function/
Memory Sending/
Sender's Names/
Use Authentication User Name as Sender Name/
Confirm Entered Fax Numbers/
Subaddress/
Fax TX Report/
Fax Activity Report/
Fax Multi TX Report/
Fax User Data List/
Tone/
Pause/
PIN Code Access
Super G3 FAX Board or Remote Fax Kit
To use these functions on the Remote Fax Kit, an imageRUNNER ADVANCE machine (Remote Fax server machine) with the Super G3 FAX board must correctly be connected with this machine.
To use [Select Line], you must have more than one telephone line.
Fax Function
Register Unit Telephone Number/
Register Unit Name/
Direct Sending/
Volume Settings/
Allow Fax Driver TX/ECM TX/
Auto Redial/Send Start Speed/Memory Receiving/
ECM RX/Subaddress Receiving/
Receive Start Speed/Receive Password/
Forwarding Settings/
Fax RX Report/
Confidential Fax Inbox RX Report/
Manual TX/
Check Dial Tone Before Sending/
Set Pause Time/
Select TX Line/
Select Line Type/
Manual TX/
Set Pause Time/
RX Manual/
Auto Switch/
RX Mode Settings/
Manual RX/
Incoming Fax Ring/
Remote RX
Super G3 FAX Board
Remote Fax Function (Settings as a server machine)
Remote Fax Settings
Super G3 FAX Board
Remote Fax Function
(Settings as a client machine)
Remote Fax TX/Remote Fax TX Settings
Remote Fax Kit
To use these functions, an imageRUNNER ADVANCE machine (Remote Fax server machine) with the Super G3 FAX Board must be correctly connected with this machine.
Fax Function with 2 Lines
Super G3 2nd Line Fax Board
Super G3 FAX Board
Fax Function with 3 to 4 Lines
Super G3
3rd/4th Line Fax Board and Additional Memory Type A (512MB) |
Super G3 FAX Board and Super G3 2nd Line Fax Board
Color Scanning (When scanning to a mail box)
(512MB) |
Color Scanning with 200 x 400
dpi/400 x 400 dpi/600 x 600 dpi Resolution (When sending, or when scanning to memory media, the Advanced Box, or the Advanced Box of another imageRUNNER ADVANCE machine on the network) |
(512MB) |
Trace & Smooth PDF
Universal Send Advanced Feature Set
Searchable PDF/XPS
Reader Extensions PDF
Encrypted PDF
Universal Send Security Feature Set
Device Signature PDF/XPS
User Signature PDF/XPS
Universal Send Digital User Signature Kit
Secure Watermark
Secure Watermark
Hard Disk Data Encryption & Mirroring
HDD Data Encryption & Mirroring Kit
2.5inch HDD
The Data Encryption & Mirroring Kit cannot be used with the HDD Mirroring Kit.
HDD Data Mirroring
HDD Mirroring Kit
2.5inch HDD
The HDD Mirroring Kit cannot be used with the HDD Data Encryption & Mirroring Kit.
Data Erase
Data Erase Kit
Removable HDD Management
Removable HDD Kit
Document
Scan Lock/ Tracking
Restricting Document Duplication/
Track Users
Document Scan Lock Kit
Viewing Web Pages
Web Access Software
Printing Web Pages (PDF)/
Storing Files in Mail Box |
Encrypted Print Settings
Encrypted Secure Print Software
Access Management
ACCESS MANAGEMENT SYSTEM KIT
Voice Guidance
Voice Guidance Kit/
Voice Operation Kit
Voice Operation
Voice Operation Kit
Operation of the Machine from Computer
Remote Operator's Software Kit
The Super G3 FAX Board and Remote Fax Kit cannot be used at the same time.
You cannot use the Voice Guidance Kit/Voice Operation Kit when you are logged in using SSO-H authentication.
