Category
Top » Scan and Send » Reply-to
Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Collapse all|Expand all
Reply-to
You can specify a reply-to destination when sending an e-mail or I-fax.
You need to store reply-to addresses in the Local Address Book or a one-touch button beforehand. (See "Storing New Addresses.")
Press [Scan and Send].
Specify the destination → press [Options] → [Reply-to].
Select the desired address → press [OK] → [Close].
You cannot select multiple destinations.
When you send an e-mail, the selected destination is set as the reply-to e-mail address when the recipient replies.
When you send an I-fax, a Full mode delivery confirmation message is sent to the selected reply-to address.
For instructions on searching for registered destinations, see "Address Book Screen."
If you set a login service for the machine and set [Specify Authentication User Dest. to Reply] to 'On', the e-mail address of the login user appears as the reply-to address. (See "Setting an Authorized User E-Mail Address as the Reply-to Destination.")
