Long strip originals (432 mm or longer) cannot be used with PDF (OCR) or XPS (OCR).
Even if you select PDF (OCR) or XPS (OCR) as the file format, text may not be detected correctly, depending on the background color and the style and size of the characters in your original.
If you select PDF (OCR) or XPS (OCR) as the file format, and <Smart Scan> is set to 'On' in [OCR (Text Searchable)], the orientation of the original is detected, and the document is automatically rotated if necessary before it is sent. (See "Settings for Creating Searchable PDF/XPS.")
If you select PDF (OCR) or XPS (OCR) as the file format, you can only send at a zoom ratio of [Direct (100%)] or [Auto].
