[TIFF/PDF (Auto)]:
Sends the file in either the TIFF (Black-and-White) or PDF (Grayscale/Color) format. If you select this file format, [TIFF/PDF] appears on the Scan and Send Basic Features screen.
[TIFF/XPS (Auto)]:
Sends the file in either the TIFF (Black-and-White) or PDF (Grayscale/Color) format. If you select this file format, [TIFF/XPS] appears on the Scan and Send Basic Features screen.
[TIFF/JPEG (Auto)]:
Sends images in either the TIFF (Black-and-White) or JPEG (Grayscale/Color) format. If you select this file format, [TIFF/JPEG] appears on the Scan and Send Basic Features screen.
[PDF]:
Sends the file in the PDF file format, regardless of the color mode. You can also specify additional settings.
[XPS]:
Sends the file in the XPS file format, regardless of the color mode. You can also specify additional settings.
[JPEG]:
Sends the file in the JPEG format, if you select a color mode other than Black-and-White.
[TIFF]:
Sends the file in the TIFF format, if you select a color mode other than Black-and-White.
You can select the type of PDF or XPS in [Set Details]. Refer to the following for instructions on setting each type of PDF or XPS:
[Trace & Smooth]: Trace and Smooth
[Compact]: Compact PDF or XPS
[OCR (Text Searchable)]: Searchable PDF/XPS
[Add Digital Signatures]: Adding a Digital Signature to a PDF or XPS
[Encrypt]: Encrypting PDF Files
[Reader Extensions]: Selecting the Original Type
[Apply Policy]: Applying a Policy
If you select [TIFF/PDF (Auto)], the [Optimize PDF for Web] setting is invalid even if you set it to 'On'. (See "Optimizing PDF for Web.")
To view a PDF file or to search a text in a PDF file, software that supports the PDF format (such as Adobe Reader/Adobe Acrobat) is required.
To view an XPS file or to search a text in an XPS file, software that supports the XPS format (such as XPS Document Viewer) is required.
To view a JPEG file, software that supports the JPEG format (such as Microsoft Internet Explorer for Windows) is required.
To view a TIFF file, software that supports the TIFF format (such as Imaging for Windows) is required.
