If you want to scan nonstandard size originals longer than 11" x 17", press [Long Original]. The maximum length of originals that you can scan is 24 7/8" (630 mm).
You cannot select [Auto] when scanning the following types of originals. Select the desired scan size.
Nonstandard size originals
Highly transparent originals, such as transparencies
Originals with an extremely dark background
Originals smaller than STMT
Take note of the following when you set [Custom]:
Place your originals on the platen glass.
You cannot use the [Finished Stamp] mode with this mode.
Sent images are not rotated.
Take note of the following when you set [Long Original]:
Place your originals in the feeder.
You can only set a zoom ratio of 100%.
Take note of the following when you set [Free Size]:
