1
[Address Book]
Selects a destination from the Address Book.
2
[One-Touch]
Displays the screen for registering/specifying one-touch buttons.
3
[New Destination]
Press to specify a destination is not stored in an Address Book.
4
[Send to Myself]
Press to specify your own e-mail address as the destination.
5
[Cc Bcc]
Press to specify Cc or Bcc addresses. |
6
[Specify Destinations]
Press to display the methods for specifying destinations or the destination list. |
7
![]() You can specify the following settings:
Register Favorites Settings
Edit Favorites Settings
Register to Quick Menu (See "Quick Menu.")
Changing the Default Settings
Register Options Shortcuts
Set SMTP Authentication
[Set SMTP Authentication] appears only if you set authentication by SSO-H. For more information, see "Common Communication Settings for E-Mail/I-Fax." |
8
[Previous Settings]
Display to recall the last three send jobs, including the destinations, scan settings, and send settings.
9
[Favorite Settings]
Press to register frequently used send settings. You can also recall registered settings.
10
Select Color
Press to select the color mode.
11
Resolution
Specifies the resolution.
12
Scan Size
Press to select the size of the original.
13
File Format
Press to select the file format.
14
Shortcuts to Options
Enables you to display several shortcuts to modes in [Options]. [2-Sided Original] and [Different Size Originals] are displayed as default. (See "Assigning Shortcuts.")
15
[Options]
Press to select and use other modes available for scanning and sending. Set useful send functions such as sending different sized originals together or sending 2-sided originals.
16
[Delete Dest.]
Press to delete a destination displayed in the destination list.
17
[Details]
Press to check or change the destination information selected from the destination list.
18
Destination List
Press to display a list of destinations. |
You must specify network settings to be able to send scanned documents to an e-mail address, I-fax address, or file server. (See "Common Communication Settings for E-Mail/I-Fax.")
[Send to Myself] appears only if you register a user's e-mail address when you are using authentication by SSO-H.
To display [Fax] when [New Destination] is selected, set <Enable Fax in Scan and Send Function> for [Display Fax Function] to 'On'. (See "Display Fax Function.")
1
Specify Type of Destination button
If you press [All],
(E-Mail), (Fax), (I-Fax), (File), or (Group) destinations for each type appear. |
2
[Change Add. Book]
If you press [Change Add. Book], you can switch the display to the [Local], [Remote], or [LDAP Server] address book. |
3
Address List drop-down list
Press the Address List drop-down list to display a list of Address Lists 1 to 10 or one-touch buttons. Address lists categorize the addresses stored in the Address Book.
4
Search Initial Letter button
Press the alphanumeric keys (e.g., [ABC]) to display the individual keys for each letter or number. You can select a letter or number to restrict the displayed range of entries. Press [All] to return to the full address list.
5
[Search by Name]
If you press [Search by Name], a pop-up screen for refining the address book appears. You can further refine the search by entering multiple consecutive characters, starting with the first character of the destination name. You can also refine the addresses displayed by using the [Keyboard] to enter multiple letters.
![]() [ABC] - [Sym]
Displays the characters you can enter. The range of letters or the symbols you can enter appear.
[Keyboard]
Displays the keyboard on the touch panel display.
[Clear]
Press to delete all of the text entered.
[Backspace]
Press to delete the last letter entered.
Press [Search by Name] again to close the screen for refining the address book and return to the previous screen.
If you select [All], destinations registered in one-touch buttons also appear. However, you cannot delete destinations registered in one-touch buttons. For instructions on deleting one-touch buttons, see "Storing/Editing/Deleting One-Touch Buttons."
To cancel a selected destination, select the destination again.
To display [Access No.], set [Manage Address Book Access Numbers] to 'On'. (See "Managing the Address Book with Access Numbers.")
To display the fax destination, set <Enable Fax in Scan and Send Function> for [Display Fax Function] to 'On'. (See "Display Fax Function.")
