Category
Top » Scan and Send » Things You Must Do Before Using This Machine
Category Top
What This Machine Can Do
Overview of This Function
Flow of Sending Operations
Canceling a Job
Specifying Destinations
Specifying Destinations Using the One-Touch Buttons
Specifying a Destination by Entering an E-mail Address
Specifying Destinations by Entering an I-Fax Address
Specifying a Destination by Entering a File Server
Specifying a File Server Using the Keyboard
Specifying a File Server Using the Browse Key (Windows (SMB))
Specifying a File Server Using the Search Host Key (Windows (SMB))
Storing in a Mail Box
Storing in an Advanced Box
Setting Your Own E-Mail Address as the Destination
Setting Cc and Bcc Addresses
Favorite Settings
Recalling Previous Send Jobs
Storing New Addresses
Registering an E-Mail Address
Registering an I-Fax Address
Registering a Group Address
Registering an Advanced Box Address
Registering/Editing/Deleting Favorite Settings
Registering/Editing Favorite Settings
Checking Favorite Settings
Editing a Name/Comment
Assigning Shortcuts
Switching the Color Mode
Setting the Resolution
Setting the File Format
Trace and Smooth
Compact PDF or XPS
Searchable PDF/XPS
Adding a Digital Signature to a PDF or XPS
Encrypting PDF Files
Reader Extensions
Applying a Policy
Selecting the Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
File Name
Subject/Message
Reply-to
Setting E-Mail Priority
Receiving I-Fax Documents
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
When Problems Occur
Questions & Answers
Collapse all|Expand all
This section describes the important setting registrations and procedures that must be done before the machine is used for sending operations.
If you attempt to use the machine without registering the necessary information correctly, the machine may not function properly.
Network Settings (See "Sending E-Mail/I-Faxes.")
You must specify network settings to be able to send scanned documents to an e-mail address, I-fax address, or file server.
Setting the Display Language
To switch the display language, set [Language/Keyboard Switch On/Off] to 'On' before entering characters. (See "Enabling the Language/Keyboard Switch.")
If you switch [Language/Keyboard Switch On/Off] from 'Off' to 'On' after entering characters, the characters may not appear correctly. In this case, either re-enter the characters after setting [Language/Keyboard Switch On/Off] to 'On', or enter characters with [Language/Keyboard Switch On/Off] set to 'Off'.
If you set [Language/Keyboard Switch On/Off] to 'On', some characters are restricted and cannot be entered.
Registering the Sending Record
The sending record is printed at the top of every document you send via I-fax to the recipient.
The registered information is printed as shown below. Depending upon the model of the machine at the receiving side, this information may also appear on the display while communication is taking place.
Date and Time
The date and time of the transmission are recorded.
I-Fax Address
Your machine's I-fax address is recorded.
Destination Name
If you select a destination from the Address Book to send an original, the name of the stored destination appears on the sending record. (See "Storing New Addresses.")
Page Number
The current page number out of the total number of pages of the original is recorded.
Registering the Unit Name for E-Mail/I-Fax
When you send a document via e-mail or I-fax, the unit name appears or is printed as the sender's name at the recipient's machine. You can register the name of your company or department as the unit name. (See "Registering the Unit's Name for E-Mail/I-Fax.")
Setting the Current Date and Time
You can set the current date and time. (See "Current Date and Time.")
The current date and time settings are used as standard timer settings for functions that require them.
<Time Zone>:
The standard time zones of the world are expressed globally in terms of the difference in hours (± up to 12 hours) from GMT*1 (± 0 hours). A time zone is a region throughout which this time difference is the same.
<Daylight Saving Time>:
In some countries, time is temporarily advanced throughout the summer season. This practice is called "Daylight Saving Time."
*1 The time at the Greenwich Observatory in England is called GMT (Greenwich Mean Time).
You can set the machine so that the sending record is not printed. (See "Printing the TX Terminal ID.")
If you set the machine to print the sending record at the top of the recording paper, and not all of the items are registered, only the registered items and the total number of original pages are printed.
To print the destination's name on the recipient's paper, set <Display Destination Unit Name> to 'On' in [TX Terminal ID].
You can specify to automatically synchronize the date and time with a server on the network. (See "Settings Common to TCP/IPv4 and TCP/IPv6.")
If the Local Device Authentication user authentication system of SSO-H is set as the login service and you are sending an e-mail message:
The e-mail address of the login user registered for the Local Device Authentication user authentication system of SSO-H appears in the From field on the e-mail recipient's machine, instead of the e-mail address registered in the Device Information settings for this machine.
The e-mail address that you registered in the Device Information settings for this machine appears in the From field on the I-fax recipient's machine. The e-mail address of the login user registered for the Local Device Authentication user authentication system of SSO-H is displayed in the Sender field.
If the Domain Authentication user authentication system of SSO-H is set as the login service and you are sending an e-mail message (including when performing Domain Authentication with the 'Domain Authentication + Local Device Authentication' user authentication system):
The e-mail address that you registered for Active Directory or imageWARE Accounting Manager appears in the From field on the recipient's machine, instead of the e-mail address that you registered in the Device Information settings for this machine.
The e-mail address that you registered in the Device Information settings for this machine appears in the From field, and the e-mail address that you registered for Active Directory or imageWARE Accounting Manager is displayed in the Sender field on the recipient's machine.
If you set [Set Authentication User Dest. to Sender] to 'On' in E-Mail/I-Fax Settings, the e-mail address of the login user appears in the From field on the recipient's machine, regardless of the login service.
If you set [Set Authentication User Dest. to Sender] to 'Off', the address registered in the Device Information settings is displayed instead.
For instructions on storing your machine's e-mail address, see "Common Communication Settings for E-Mail/I-Fax."
