You can use the autocomplete function, if you set [Autocomplete for Entering E-Mail Addresses] to 'On'. (See "Setting Autocomplete for E-mail Address Entry.")
When you enter an e-mail address from the keyboard displayed on the touch panel display, e-mail addresses registered in the Local Address Book that match the initial characters of your e-mail address entry, automatically appear highlighted yellow. To select the automatically displayed e-mail address, press [OK]. To enter a different e-mail address, enter the full destination address. You can also specify a destination by pressing to display a list of potential matches. E-mail addresses that are stored with an access number do not appear. |
[On]:
Select [On] if the recipient's machine has a function to combine divided data that is received.
[Off]:
Select [Off] if the recipient's machine does not have a function to combine divided data or if you do not want to divide the sent data.
Make sure to check the specifications of the destination's e-mail software before setting this mode. If you set conditions that the recipient's machine does not support, a transmission error may occur.
