Each address entry is treated as a single entry. If you register a given e-mail address in a group address, that e-mail address and the group address are counted as two separate entries.
The Local Address Book data can be saved and imported using the Remote UI. (See "Loading Address Lists and Device Settings Information (Import).")
If you want to manage destinations with the Manage Address Book Access Number mode, set [Manage Address Book Access Numbers] to 'On'. (See "Managing the Address Book with Access Numbers.")
If a required destination setting has not been set after registering the access number, the screen for specifying the destination settings appears again.
You can enter up to seven digits for the access number. If you enter fewer than seven digits, the machine stores the access number with leading zeros.
Example: If <321> is entered, <0000321> is stored.
You cannot store an access number with only zeros as the number, such as <0000000>. If you enter a number that begins in zeros, such as <02> or <002>, the zeros are ignored and the number is registered as <0000002>, the same as if you had simply entered <2>.
For instructions on registering, editing, or deleting a fax number in a one-touch button, see "Storing New Addresses."
