Category Top
Settings/Registration and User Privileges
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5R and STMTR Paper
Registering/Editing Custom Paper Types
Registering Paper Frequently Used in the Multi-Purpose Tray
Setting the Method for Selecting Multi-Purpose Tray Paper
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Displaying the IP Address
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Automatic Gradation Adjustment
Correct Density
Correct Shading
Auto Correct Color Mismatch
Making the Color More Vivid When Printing with Full Color
Fine Adjust Zoom
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Adjust Action
Saddle Stitch Staple Repositioning
Saddle Stitch Position Adjustment
Setting the Execution Time for Manual Stapling
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Specifying Paper Drawer Auto Selection Based on Color
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
Setting the Output Trays of Optional Equipment
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Text/Photo Priority in a Black-and-White Original
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Scan Settings
Feeder Jam Recovery Method
Scanning Originals Quietly
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
Image Quality Level for Compact
Settings for Creating Searchable PDF/OOXML
Trace & Smooth Settings
OOXML Settings
Including Background Images When Generating Word Files
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Enabling Auto Collating
Enabling Auto Orientation
Color Mode Settings for Copy
Send
Output Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Scan and Send
Changing the Default Settings for Scan and Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
Displaying a Confirmation Screen When Jobs Are Accepted
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN on Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Autocomplete for E-mail Address Entry
Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for Fax
Registering/Editing/Deleting Sender Names (TTI)
Setting the Authenticated User Name as the Sender Name
Enabling ECM Transmission
Pause Time
Enabling Auto Redial
Checking the Dial Tone before Sending
Fax TX Report
Fax Activity Report
Fax Line Settings
Setting the Line to Use When Sending
Send Start Speed
PIN Code Access
Remote Fax TX Settings
Receive/Forward
Output Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Confirming/Enabling/Deleting Forwarding Settings
Printing Forwarding Settings
Specifying the Fax/I-Fax Inbox Settings
Always Send Notice for RX Errors
Fax Settings
Enabling ECM Reception
Fax RX Report
Confidential Fax Inbox RX Report
Setting the Receive Start Speed
Setting the Receive Password
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Mail Box Settings
Memory Media Settings
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Settings/Registration Table » Management Settings
Management Settings
0R9W-05U
Management Settings
Management Settings: User Management
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Authentication Management]
[Change Password]*1
(32 characters maximum)
(NULL)
Yes
No
[Register/Edit Authentication User]
Register, Details/Edit, Delete
Yes
No
[User Authentication]
On, Off
On
Yes
No
[Login Screen Display Settings]
Display When Oper. Started, Display When Func. Slctd.
Yes
No
Display When Func. Slctd.:
Require Authentication For: Functions, Color Copy/Print(None (No Authentication Required), Full Color, Full Color/Two Colors, Full Color/Two Colors/Single Color)
Yes
No
Restrict Operations in Settings/Registration: Restrict All Operations, Restrict Certain Oper.
Yes
No
[Functions to Restrict]
Print from Drivers without AMS Printer Driver Add-in
Do Not Restrict
Yes
No
Remote Scan
Do Not Restrict
Yes
No
[System Manager Information Settings]
System Manager ID (Seven digits maximum)
7654321
Yes
Yes
System Manager PIN (Seven digits maximum)
7654321
Yes
Yes
System Manager
(NULL)
Yes
Yes
E-Mail Address
(NULL)
Yes
Yes
Contact Information
(NULL)
Yes
Yes
Comment
(NULL)
Yes
Yes
[Department ID Management]
Department ID Management: On, Off
Off
Yes
Yes
Register PIN: Reg., Edit, Delete, Limit Functions
Yes
Yes
Register/Edit:
Dept. ID, PIN, Turn Limit On/Off and Set Page Limit
Yes
Yes
Turn Limit On/Off and Set Page Limit:
Total Print Limit:
On, Off, Page Limit (0 to 999999)
Off
0
Yes
Yes
Total Color Print Limit:
Off
0
Yes
Yes
Total Black & White Print Limit:
Off
0
Yes
Yes
Set Copy Limit:
Color Copy Limit
Black & White Copy Limit
Off
0
Off
0
Yes
Yes
Set Scan Limit:
Color Scan Limit
Black & White Scan Limit
Off
0
Off
0
Yes
Yes
Set Print Limit Details:
Color Print Limit
Off
0
Off
0
Yes
Yes
Page Totals: Clear, Print List, Clear All Totals, Large2 Count Management
Yes
No
Allow Printer Jobs with Unknown IDs: On, Off
On
Yes
Yes
Allow Remote Scan Jobs with Unknown IDs: On, Off
On
Yes
Yes
Allow Black & White Copy/Print Jobs: On, Off
Off
Yes
Yes
Allow Black & White Printer Jobs: On, Off
Off
Yes
Yes
*1
Indicates items that appear only if you are logged in as a user with privileges other than Administrator privileges when User Authentication is being used.
Management Settings: Device Management
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Device Information Settings]
Device Name
Model Name
Yes
No
Location
(NULL)
Yes
No
[Device Information Distribution Settings]
[Register Destinations]
Auto Search/Register, Reg., Details, Delete, Print List
No
No
Auto Search/Register:
Search Depth (Router): 1 to 8
1
No
No
Display Host Name: On, Off
Off
No
No
Start Auto Search
No
No
[Set Auto Distribution]
Everyday (1 to 5), Specify Days (Sun to Sat, 1 to 5), Off
Off
No
No
Settings/Registration Value: On, Off
Network Settings: Include, Exclude
Off
Network Settings: Exclude
No
No
Dept. ID: On, Off
Off
No
No
Address Book: On, Off
Off
No
No
Web Access Favorites*1: On, Off
Off
No
No
Printer Settings: On, Off
Off
No
No
Paper Information: On, Off
Off
No
No
Workflow Composer*1: On, Off
Off
No
No
[Manual Distribution]
Off
No
No
Dept. ID: On, Off
Off
No
No
Off
No
No
Off
No
No
Off
No
No
Off
No
No
Off
No
No
[Set MEAP Authentication]
User Name, Password, Login Destination
No
No
[Restrict Receiving Device Information]
On, Off
On
No
No
[Restore Data]
Settings/Reg. Value, Dept. ID, Address Book, Web Access Favorites*1, Printer Settings, Paper Information, Start
No
No
[Restrict Receiving for Each Function]
On
No
No
Dept. ID: On, Off
On
No
No
On
No
No
On
No
No
On
No
No
On
No
No
On
No
No
[Use MEAP Auth. When Receive]
On, Off
Off
No
No
[Communication Log]
Details, Print List, Report Settings
No
No
Report Settings
Auto Print (100 Transmissions): On, Off
On
No
No
Specify Print Time: On, Off
Off
No
No
00:00 to 23:59
00:00
No
No
Separate Report Type: On, Off
Off
No
No
[Limited Functions Mode]*1
On, Off
Off
No
No
[Confirm Device Signature Certificate]*1
Version, Serial Number, Signature Algorithm, Issued To, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.
Yes
No
[Confirm User Signature Certificate]*1
Yes
No
[Certificate Settings]
[Generate Key]
[Generate Network Communication Key]
Key Name
(NULL)
Yes
No
Signature Algorithm: SHA1, SHA256, SHA384, SHA512
SHA256
Yes
No
Key Algorithm: RSA, ECDSA
RSA
Yes
No
When RSA is selected
Key Length (bit): 512, 1024, 2048, 4096
2048
Yes
No
When ECDSA is selected
Key Type: P256, P384, P521
P256
Yes
No
Validity Start Date: Month, Date, Year (01/01/2000 - 12/31/2037)
(NULL)
Yes
No
Validity End Date: Month, Date, Year (01/01/2000 - 12/31/2037)
(NULL)
Yes
No
Country/Region: Country/Region name and code
United States (US)
Yes
No
State
(NULL)
Yes
No
City
(NULL)
Yes
No
Organization
(NULL)
Yes
No
Organization Unit
(NULL)
Yes
No
Common Name (IP address of the machine or FQDN (41 characters maximum))
(NULL)
Yes
No
[Generate/Update Device Signature Key]
(See "Setting a Key Pair and Device Certificate.")
Yes, No
Yes
No
[Generate/Update Key for Access Control]
Yes, No
Yes
No
[Key and Certificate List]
[Key and Certificate List for Users]*1
Certificate Details: (Version, Serial Number, Signature Algorithm, Issued To, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Delete
Yes
No
[Key and Certificate List for This Device]*1
Yes
No
Delete
Yes
No
Display Use Location (Key and Certificate)
Yes
No
[CA Certificate List]
Yes
No
Delete
Yes
No
[Certificate Revocation List (CRL)]
CRL Details: Serial Number, Expires, Verify CRL
Yes
No
Delete
Yes
No
[Register Key and Certificate]
Register
Yes
No
Delete
Yes
No
[Register CA Certificate]
Register
Yes
No
Delete
Yes
No
[Display Job Status Before Authentication]
On, Off
On
Yes
No
[Restrict Access to Other User Jobs]
Copy/Print: On, Off
Send: On, Off
Receive: On, Off
Store: On, Off
Off
Yes
No
[Display Job Log]
On, Off
On
Yes
No
Off
Retrieve Job Log with Management Software: Allow, Do Not Allow
Do Not Allow
Yes
No
[Save Audit Log]
On, Off
Off
Yes
No
[Store Key Operation Log]
On, Off
Off
Yes
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Management Settings: License/Other
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Register License]
24 characters maximum, Start
(NULL)
No
No
[MEAP Settings]
[Print System Information]
Yes, No
No
No
[Use SSL]
On, Off
Off
Yes
No
[Remote UI]
On, Off
On
No
Yes
Use SSL:
On, Off
Off
Yes
No
[Delete Message Board Contents]
Yes, No
No
No
[Remote Operation Settings]
On, Off
Off
Yes
No
[Use ACCESS MANAGEMENT SYSTEM]
On, Off
Off
Yes
No
[Register/Update Software]
Install Applications/Options, Software Management Settings
Yes
No
[Start Setup Guide]
Start
No
No
Management Settings: Data Management
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
[Import/Export]
[Import from USB Memory]
Decryption Password, Start Importing
No
No
[Export to USB Memory]
Encryption Password, Start Exporting
No
No
[Restrict Import/Export from Web Service]
On, Off
Off
Yes
No
[Delete Existing Data Settings]
[Delete Existing Data]
On, Off
Off
Yes
No
[Timing of Deletion]
During Job, After Job
During Job
Yes
No
[Overwrite Method to Delete HDD Data]
Once with 0 (Null) Data, Once with Random Data, 3 Times with Random Data, DoD Standard
Yes
No
[Initialize All Data/Settings]
Once with 0 (Null) Data, Once with Random Data, 3 Times with Random Data, 9 Times with Random Data, DoD Standard
No
No
[TPM Settings]
Use TPM: On, Off
Off
No
No
Back Up TPM Key(12 characters maximum for password), Restore TPM Key
No
No
Management Settings: Security Settings
Item
Setting Description
Default Setting
[Authentication/Password Settings]
[Authentication Function Settings]
[Lockout Settings]
Enable Lockout: On, Off
Off
Yes
No
When On is selected:
Lockout Threshold (1 to 10 times)
1 times
Yes
No
Lockout Period (1 to 60 min.)
1 min.
Yes
No
[Password Settings]
[Display Warning When Default Password Is in Use]
On, Off
On
Yes
No
[Allow Use of Default Password for Remote Access]
On, Off
Off
Yes
No
[Minimum Length Settings]
On (1 to 32 Characters), Off
Off
Yes
No
[Validity Period Settings]
On (1 to 180 days), Off
Off
Yes
No
[Prohibit Use of 3 or More Same Consec. Char.]
On, Off
Off
Yes
No
[Use at Least 1 Uppercase Character]
On, Off
Off
Yes
No
[Use at Least 1 Lowercase Character]
On, Off
Off
Yes
No
[Use at Least 1 Digit]
On, Off
Off
Yes
No
[Use at Least 1 Symbol]
On, Off
Off
Yes
No
