0R9W-09C
You can create a PDF that displays only the pages that are already downloaded even when a file is still being downloaded.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Generate File].
Press [Optimize PDF for Web].
4.
Press [On] → [OK].
Select [Off] if you do not want to optimize PDF files for Web viewing.
This setting is disabled when sending a fax or I-fax.
If you set [Optimize PDF for Web] to 'On', this setting can be used with one of the following settings:
Device Signatures
User Signatures
