Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Starting the Setup Guide
0R9W-21C
You can configure the machine's initial settings by using the Setup Guide.
When the Setup Guide is started and closed, the machine will restart. Before the machine is restarted, make sure that there are no jobs currently in progress.
This mode is not available if DepartmentID Authentication is enabled.
Press [Management Settings] → [License/Other] → [Start Setup Guide].
Press [Start].
Press [Start] to restart the machine and display the Setup Guide.
Once all the settings have been configured with the Setup Guide, the machine will once again restart.
The Setup Guide displays the settings to be configured in the following order.
Procedure
Item
Setting Description
Remarks
Required Permission Level
1
<Switch Language/Keyboard>
Select the displayed language and keyboard layout.
General Users/System Managers
2
<Paper Settings>
Set the paper size for each paper drawer.
You can close the Setup Guide here. To close the Setup Guide, press [Skip].
3
<Use Optional Output Tray>
Set whether to use the optional output tray.
The Log In screen is displayed. Log in as an administrator.
System Manager
4
<Date/Time Settings>
Set the date and time.
5
<Use IP Address>
Specify IPv4 and/or IPv6, and each IP address.
6
<DNS Server Address Settings>
Configure the DNS Server Address Settings, the DNS Host/Domain Name Settings, and the DNS Dynamic Update Settings.
7
<Proxy Settings>
Specify the Proxy Settings.
8
<Register Unit Telephone Number>
Set the phone number, the name the machine will appear as on the network, and the line type.
9
<Auto Adjust Gradation>
Automatically adjust the gradation, density, and color settings of the machine.
10
<Output Report>
If necessary, output reports for the network user data list, fax user data list, and setting value list.
