Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Managing the Setting Information Registered in the Machine
0R9W-20L
You can save (export) the Address Book and other settings such as forwarding settings that are registered in the machine or other Canon machines as a file to USB memory that can be loaded (imported) into the machine when needed.
The settings of the machine you are currently using can also be transferred to another machine.
You can also restrict the batch importing/exporting of settings using a Web application other than the Remote UI via the network.
Importing/exporting can also be performed from the Remote UI.
It is recommended that you import/export from the Remote UI because you can individually select the items to import/export when doing so. (See "Import/Export Function.")
Importing/exporting can only be performed by a user with the required privileges. For more information, see "Setting Administrators."
Since the original settings are overwritten when settings are imported, doing so may cause the machine to stop operating correctly or other problems. For more information, "Import/Export Function."
The Import/Export operation may take several minutes to complete. Do not turn the machine's main power OFF until the operation is complete. Otherwise, the machine may malfunction.
If USB memory is already connected to the machine, that USB memory will be recognized as the media to use for importing/exporting, even if you connect new USB memory. Press → remove the connected USB memory → insert the desired USB memory.
If you import/export while a job is being executed, an error may be displayed.
If the display language when the data was exported differs from the display language when the data is imported, the machine may not operate correctly because the settings will be garbled.
Batch Importing Setting Information from USB Memory Media
Press [Management Settings] → [Data Management] → [Import/Export].
Press [Import from USB Memory].
4.
Select the file to import → press [Next].
5.
Press [Decryption Password] → enter the password → press [OK].
6.
Press [Start Importing].
Batch Exporting Setting Information to USB Memory Media
Press [Export to USB Memory].
4.
Set the encryption password.
Press [Encryption Password].
Enter the password → press [OK].
Enter the password again on the confirmation screen → press [OK].
5.
Press [Start Exporting].
Restricting Importing/Exporting from Web Applications Other than the Remote UI
Press [Restrict Import/Export from Web Service] → [On].
Settings specified from the control panel become effective after the machine is restarted, after the procedure. If <Perform Apply Setting Changes from Settings/Regist.> is displayed on the bottom of the touch panel display, you can press [Apply Set. Chng.] in (Settings/Registration) to restart the machine. For information on restarting the machine using the main power switch, see "Main Power and Energy Saver Key."
