Setting an Authorized User E-Mail Address as the Reply-to Destination
0R9W-0AW
If you are using a login service, you can specify to set the e-mail address of the login user as the reply-to destination when sending an e-mail message or I-fax document.
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [E-Mail/I-Fax Settings].
Press [Specify Authentication User Dest. to Reply].
4.
Press [On] → [OK].
Select [Off] to set the e-mail address set for the machine as the reply-to destination.
If you enter an e-mail address as the reply-to destination in [Options] when sending an e-mail message or I-fax document, that e-mail address is given priority, even if [Specify Authentication User Dest. to Reply] is set to 'On'.
