Displaying a Confirmation Screen When Jobs Are Accepted
0R9W-0AF
You can set whether to display a screen prompting the user to confirm the job status when sending is started using [Fax] or [Scan and Send].
An optional product is required to use the Fax function. For information on the optional products required to use this function, see
"Optional Products Required for Each Function."
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [Common Settings].
Press [Display Notification When Job Is Accepted].
4.
Press [On] → [OK].
Select [Off] if you do not want to display a screen.
