Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Specifying Management Settings for the Memory » Initializing All Data/Settings
0R9W-20U
If this mode is performed, the following data stored in the machine are completely erased. It is not normally necessary to use this mode, but it is useful to erase personal or confidential information when returning or disposing of the machine.
Data stored in mail boxes
Data stored in Fax/I-Fax Inbox (Confidential Fax Inbox/Memory RX Inbox)
Address data stored in the Address Book
Scan settings registered for the Sending function
[Favorite Settings] registered for the Copy, Store/Access Files, and Send functions
MEAP applications and license files
Data saved from MEAP applications
The password for the SMS (Service Management Service) login service of MEAP
(If you changed the password, it returns to the default password.)
User authentication information registered in the Local Device Authentication system of User Authentication
Unsent documents (reserved documents and documents set in the Delayed Send mode)
Job history
Settings/Registration settings
Registered forwarding settings
Key Pair and Server Certificate registered in [Certificate Settings] in [Device Management] in [Management Settings] (Settings/Registration)
Before initiating the Initialize All Data/Settings mode, make sure that the data you are erasing is completely unnecessary. Note that Canon will not be liable for any damages resulting from the loss of data.
If the Copy Card Reader-F1 is attached to the machine, and does not operate properly after initializing the data, contact your local authorized Canon dealer.
To prevent other users from accidentally erasing all the data in the memory, it is recommended that you set an administrator.
Confirm that there are no current jobs being processed before using the Initialize All Data/Settings mode.
Backup or export any necessary data before erasing the data in the machine. You can backup or export the following data:
Data you can backup using the Remote UI
Mail box settings, stored files in the mail box (For information on backing up data, see "Backing Up Stored Data.")
Data you can export using the Remote UI
(Depending on the MEAP application, you may be able to backup this data. For more information, see the manual for the MEAP application you are using.)
License files for MEAP applications
(For information on downloading license files, see "Managing Application Licenses.")
(For information on exporting authentication information, see "Managing User Information.")
Settings which can be sent using the Device Information Distribution mode
(Can only be backed up if you have another machine with the Device Information Distribution mode. It is not necessary to back up this data if you want to use the data already registered in the other machine. For more information on the Device Information Distribution mode, see "Specifying Device Information Distribution Settings.")
(Depending on the MEAP application, you may be able to back up this data. For more information, see the manual for the MEAP application you are using.)
After initializing data, the Initialize All Data/Settings Report is automatically printed to confirm initialization. Use the report to check the following items.
Serial Number
The serial number of the machine is printed.
Device Name
The device name of the machine is printed.
Overwrite Method for Deletion Mode
The deleted contents and deletion mode are printed.
The Initialize All Data/Settings Report is printed in English only.
Although the job logs are deleted when the Initialize All Data/Setting mode is performed, the log which shows the Initialize All Data/Settings Report has been printed appears in [Job Log].
Press [Management Settings] → [Data Management] → [Initialize All Data/Settings].
Select the deletion mode → press [Start].
Details of each item are shown below:
[Once with 0 (Null) Data]:
Overwrite the data once with 0 (null) data.
[Once with Random Data]:
Overwrite the data once with random data.
[3 Times with Random Data]:
Overwrite the data three times with random data.
[9 Times with Random Data]:
Overwrite the data nine times with random data.
[DoD Standard]:
Overwrite the data three times. The first time is with a fixed value, the second time with a complement of the fixed value, and the third time is with random data.
It may take more than 30 minutes to initialize the memory.
By executing the Initialize All Data/Settings mode, the machine will automatically restart.
After the machine restarts, Initialize All Data/Settings Report will be printed automatically.
If there are any current jobs being processed, they will be canceled, and then erased.
You cannot access the machine while the memory is being initialized.
The Initialize All Data/Settings mode does not delete any data the machine has stored on a server or computer.
For information on Initialize All Data/Settings Report, see "Initialize All Data/Settings Report."
