The Administrator/System Manager is set for the machine by default.
If you are logging in as the Administrator for Local Device Authentication and the default user name and password are still being used, a screen prompting you to change the password is displayed when you click [Log In]. Change the password to increase security.
The default user name for the Administrator is 'Administrator' and the default password is '7654321'. (Case sensitive.) The default setting for both the System Manager ID and System Manager PIN of the System Manager is '7654321'.
Settings specified in Settings/Registration are not changed even if you turn OFF the main power, or press
![]() For information on the settings you can specify for each item, see "Settings/Registration Table."
The Settings screen may display a list of settings. Press [
