Inserting a Job Separation Sheet between Copy Sets
0R9W-08H
If you are using the Collate, Offset Collate, or Staple mode, you can insert blank pages from a selected paper drawer to separate a specified number of copies.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Job Separator Between Copies].
4.
Press [On] → [OK].
Select [Off] if you do not want to insert a job separation sheet between copy sets.
To change the paper source for the job separation sheets, press [Change] → select the paper source → press [OK].
To set the number of copy sets to insert a job separation sheet, enter the number using
(numeric keys).
If you are using the Rotate 90 Degrees, Group (Same Pages), Booklet, or Saddle Stitch mode, you cannot insert job separation sheets between copy sets.
