Confirming the SSL Server Certificate When Receiving with POP
0R9W-0AR
You can confirm whether the SSL server certificate is valid when receiving with POP.
You can verify the validity of the certificate and reliability of the certificate chain, as well as confirm the CN (Common Name).
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [E-Mail/I-Fax Settings].
Press [Confirm SSL Certificate for POP RX].
4.
Press [On] → [OK].
Select [Off] if you do not want to confirm the SSL server certificate when receiving with POP.
To confirm the CN, press [CN] for <Add Items to Verify>.
If you do not verify the certificate, SSL communication is performed, even with an invalid certificate.
If there is a problem with the certificate, POP receiving will fail.
