Category Top
What This Machine Can Do
Screens Displayed on the Touch Panel Display
Setting the Main Menu Screen
Setting Shortcut Buttons
Setting Each Function Screen
Touch Panel Key Display
Adjusting the Brightness of the Touch Panel Display
Adjusting the Angle of the Touch Panel Display
Entering Characters from the Touch Panel Display
Entering Characters Using a USB Keyboard
Overview of Logging In
Placing Originals
Platen Glass
Feeder
Loading Paper into the Multi-Purpose Tray
Loading Envelopes into the Multi-Purpose Tray
Available Paper Stock
Inserting and Removing Memory Media
Manual Stapling
Volume and Tone Settings
Energy Saving Features
Checking the Counter and Controller Version
Conveying Messages Using the Message Board
Tutorial
Remote Operation
Other Useful Functions
Adding New Functions
Installing System Options/MEAP Applications (Distribution)
Installing System Options/MEAP Applications (Manual)
Updating Firmware
Displaying the Installation Log
Performing a Communication Test With the Distribution Server
Overview of SMS (Service Management Service)
System Requirements
Logging In to SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Switching to the Login Method for Using the SMS Password
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Printing Reports
Counter Report
PAGE COUNT LIST
PRINT LOG LIST
DEVICE INFORMATION DELIVERY DESTINATION LIST
DEVICE INFORMATION COMMUNICATION LOG REPORT
SEND JOB LIST
TX REPORT
FAX TX REPORT/FAX ERROR TX REPORT
FAX MULTI TX REPORT
FAX RX REPORT
CONFIDENTIAL FAX INBOX RX REPORT
COMMUNICATION MANAGEMENT REPORT TX/RX
FAX ACTIVITY REPORT TX/RX
FORWARDING CONDITIONS LIST
REGISTERED LDAP SERVER LIST
ADDRESS LISTS
Store Log Report
User Data List
System Information
Mail Box File List
IPSec Policy List
Printer Report
Initialize All Data/Settings Report
Top » Basic Operations » Adding New Functions
0R9W-020
Various system options can be installed in the machine.
This machine is compliant with MEAP (Multifunctional Embedded Application Platform). MEAP is a software platform that enables the development of custom applications based on Oracle's Java and Java 2 Platform, Micro Edition (J2ME).
You can use [Register/Update Software] in Settings/Registration and SMS (Service Management Service) to install system options/MEAP applications to the machine.
Installing system options/MEAP applications enables you to use new functions with the machine.
Using SMS enables you to manage MEAP applications. For details, see "Overview of SMS (Service Management Service)."
System Options
The system options you can install in this machine are as follows:
Barcode Printing Kit
PCL International Font Set
Remote Fax Kit
Universal Send Trace & Smooth PDF Kit
Universal Send Security Feature Set
Universal Send Digital User Signature Kit
Document Scan Lock Kit
Secure Watermark
Web Access Software
Encrypted Secure Print Software
MEAP Applications
To expand the functions of the machine without using system options, install MEAP applications in the machine. For more information on MEAP applications, see "Software."
The procedure for installing system options/MEAP applications in the machine differs depending on whether installation is performed with the machine connected or not connected to an external network. Refer to the following to select the appropriate method:
To perform installation with the machine connected to an external network:
Access a distribution server from the machine, and install the system option/MEAP application.
Operating from
Touch Panel Display
Enter the license access number in [Register/Update Software] on the touch panel display.
Remote UI
Enter the license access number in [Register/Update Software] in the Remote UI.
To perform installation with the machine not connected to an external network:
Use the license file/license key obtained from the License Management System to install the system option/MEAP application.
Operating from
System Options
MEAP Applications
Touch Panel Display
1. Enter the license access number on the Canon website to obtain a license key.
2. Enter the license key in [Register License] on the touch panel display.
Remote UI
1. Enter the license access number on the Canon website to obtain a license file.
2. Specify the license file in [Register/Update Software] in the Remote UI.
1. Enter the license access number on the Canon website to obtain an application file and a license file.
2. Access SMS from the Remote UI to specify the application file and license file.
Overview of SMS
Use SMS (Service Management Service) to perform the following management operations for MEAP applications (See "Overview of SMS (Service Management Service)."):
Check the MEAP applications installed in the machine
Check the hard disk space used by MEAP applications
Add licenses for previously installed MEAP applications
License registration may be required, depending on the system option/MEAP application.
For instructions on installing and uninstalling MEAP applications, see "Installing Applications" and "Uninstalling Applications."
For instructions on selecting and setting a login service, see "Login Service Selection."
Depending on the installed system option/MEAP application, you can download the manual or related software for the system option/MEAP application from the following URL.
http://canon.com/fau/downloads
When downloading manuals and related software for system options/MEAP applications, prepare the license access number certificate that was included in the package.
If there is no manual to download, see the description of the function in this manual.
For information on the Remote UI system requirements and preliminary steps to launch the Remote UI, see "System Requirements" and "Before You Start the Remote UI."
Multiple users cannot use the "Register/Update Software" at the same time.
If other users are logged in to SMS (Service Management Service), you cannot use "Register/Update Software" from the Remote UI.
If you perform one of the following operations, you cannot use "Register/Update Software" from the Remote UI for a certain period of time:
If you close the Web browser without pressing [Portal] or [Log Out], when the Remote Login Service for SMS is set.
If you close the Web browser without pressing [Portal], when the Remote Login Service for SMS is not set.
If you close the Web browser without pressing [Log Out from SMS], [To Portal], or [Log Out] for SMS.
