Category Top
Settings/Registration and User Privileges
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5R and STMTR Paper
Registering/Editing Custom Paper Types
Registering Paper Frequently Used in the Multi-Purpose Tray
Setting the Method for Selecting Multi-Purpose Tray Paper
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Displaying the IP Address
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Automatic Gradation Adjustment
Correct Density
Correct Shading
Auto Correct Color Mismatch
Making the Color More Vivid When Printing with Full Color
Fine Adjust Zoom
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Adjust Action
Saddle Stitch Staple Repositioning
Saddle Stitch Position Adjustment
Setting the Execution Time for Manual Stapling
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Specifying Paper Drawer Auto Selection Based on Color
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
Setting the Output Trays of Optional Equipment
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Text/Photo Priority in a Black-and-White Original
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Scan Settings
Feeder Jam Recovery Method
Scanning Originals Quietly
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
Image Quality Level for Compact
Settings for Creating Searchable PDF/OOXML
Trace & Smooth Settings
OOXML Settings
Including Background Images When Generating Word Files
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Enabling Auto Collating
Enabling Auto Orientation
Color Mode Settings for Copy
Send
Output Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Scan and Send
Changing the Default Settings for Scan and Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
Displaying a Confirmation Screen When Jobs Are Accepted
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN on Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Autocomplete for E-mail Address Entry
Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for Fax
Registering/Editing/Deleting Sender Names (TTI)
Setting the Authenticated User Name as the Sender Name
Enabling ECM Transmission
Pause Time
Enabling Auto Redial
Checking the Dial Tone before Sending
Fax TX Report
Fax Activity Report
Fax Line Settings
Setting the Line to Use When Sending
Send Start Speed
PIN Code Access
Remote Fax TX Settings
Receive/Forward
Output Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Confirming/Enabling/Deleting Forwarding Settings
Printing Forwarding Settings
Specifying the Fax/I-Fax Inbox Settings
Always Send Notice for RX Errors
Fax Settings
Enabling ECM Reception
Fax RX Report
Confidential Fax Inbox RX Report
Setting the Receive Start Speed
Setting the Receive Password
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Mail Box Settings
Memory Media Settings
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Settings/Registration Table » Function Settings » Function Settings: Printer
0R9W-05F
The following table lists all settings of the Printer Settings menu.
Output Report
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
PCL
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
PS
Configuration Page
Yes, No
Yes
No
Font List
Yes, No
Yes
No
RGB Test Page
Yes, No
Yes
No
CMYK Test Page
Yes, No
Yes
No
RGB Color Chart
Yes, No
Yes
No
CMYK Color Chart
Yes, No
Yes
No
Common Settings (Printer Settings > Custom Settings)
Item
Setting Description
Default Setting
Can be set in
Remote UI
[Copies]
1 to 9999
1
Yes
Yes
[2-Sided Printing]
On, Off
Off
Yes
Yes
[Paper Feed]
[Default Paper Size]
A4, A3, A5, B4, B5, Letter, Legal, 11x17, Statement, Executive, Env. NAGAGATA 3, Env. YOGATANAGA3, Env. KAKUGATA 2, Env. No. 10, Envelope ISO-C5, Envelope DL, Envelope Monarch, 12x18, 12_5/8x17_11/16
Letter
Yes
No
[Default Paper Type]
Thin, Plain 1, Plain 2, Plain 3, Heavy 1, Heavy 2, Heavy 3,Heavy 4, Color, Recycled 1, Recycled 2, Recycled 3, Pre-Punched, Transparency, Tracing, Labels, Bond, 1-Sided Coated 1, 1-Sided Coated 2, 1-Sided Coated 3, 2-Sided Coated 1, 2-Sided Coated 2, 2-Sided Coated 3, Envelope
Plain 1
Yes
No
[Paper Size Override]
On, Off
Off
Yes
Yes
[Print Quality]
[Density]*1
Cyan: -8 to +8
Magenta: -8 to +8
Yellow: -8 to +8
Black: -8 to +8
0
Yes
Yes
[Density (Fine Adjust)]*1
Cyan:
High: -8 to +8
Medium: -8 to +8
Low: -8 to +8
Magenta:
High: -8 to +8
Medium: -8 to +8
Low: -8 to +8
Yellow:
High: -8 to +8
Medium: -8 to +8
Low: -8 to +8
Black:
High: -8 to +8
Medium: -8 to +8
Low: -8 to +8
0
Yes
Yes
[Toner Save]
On, Off
Off
Yes
Yes
[Gradation]
Standard, High 1, High 2
High 1
Yes
Yes
[Resolution]
1200 dpi, 600 dpi
600 dpi
Yes
Yes
[Sharpness (Photo)]
Sharpness (Photo): On, Off
Off
Yes
Yes
Level: Low, Medium, High
Medium
[Special Smoothing Mode]
Mode 1, Mode 2, Mode 3, Mode 4, Mode 5, Mode 6
Mode 1
Yes
Yes
[Toner Volume Correction]
Normal, Grad. Priority, Text Priority
Normal
Yes
Yes
[Line Control]
Res. Priority, Grad. Priority
Res. Priority
Yes
Yes
[Advanced Smoothing]
Advanced Smoothing: Off, Level 1, Level 2
Apply to Graphics: On, Off
Apply to Text: On, Off
Level 1
Off
On
Yes
Yes
[Gradation Smoothing]
Gradation Smoothing: Off, Level 1, Level 2
Apply to Images: On, Off
Off
On
On
Yes
Yes
[Layout]
[Binding Location]
Long Edge, Short Edge
Long Edge
Yes
Yes
[Gutter]
-1.90 inches to +1.90 inches
0.0 inch
Yes
Yes
[Offset Short Edge (Front)]
-2.00 inches to +2.00 inches
0.0 inch
Yes
Yes
[Offset Long Edge (Front)]
0.0 inch
Yes
Yes
[Offset Short Edge (Back)]
0.0 inch
Yes
Yes
[Offset Long Edge (Back)]
0.0 inch
Yes
Yes
[Auto Error Skip]
On, Off
Off
Yes
Yes
[Secure Print Delete Time]
10 minutes, 20 minutes, 30 minutes, 1 hour, 2 hours, 3 hours, 6 hours, 12 hours, 24 hours
1 hour
Yes
Yes
[Timeout]
Timeout (5 to 300 seconds), Off
15 seconds
Yes
Yes
[Print After Completing RIP]
On, Off
Off
Yes
Yes
[Finishing]
Off, Collate, Group, Rotate+Collate*1, Rotate+Group*1, Offset+Collate*1 *2, Offset+Group*1, Staple+Collate*1 *3, Staple+Group*1 *3, Eco(Stpl-Fr)+Col*1*4, Eco(Stpl-Fr)+Grp*1*4
Group
Yes
Yes
[Booklet]
Off, Left Opening*1, Right Opening*1
Off
Yes
Yes
[Saddle Stitch]*1
On, Off
Off
Yes
Yes
[Creep Correction]*1
Off, Auto, Correction Width
Off
Yes
Yes
[Transparency Interleaving]*1
Off, Blank, Printed
Off
Yes
Yes
[Copy Set Numbering]*1
On, Off
Off
Yes
Yes
[Print Position]*1
5 Locations, Top Left, Bottom Left, Top Right, Bottom Right, Full Surface
5 Locations
Yes
Yes
[Starting Number]*1
1 to 9999
1
Yes
Yes
[Number Size]*1
Small(12 point), Medium(24 point), Large(36 point)
Large(36 point)
Yes
Yes
[Density]*1
1 to 5
3
Yes
Yes
[Color]*1
Yellow, Magenta, Cyan, Black
Black
Yes
Yes
[Number Position Vertical]*1
[Number Position Horizontal]*1
-5/16 to +5/16 inches
0 inch
Yes
Yes
[Personality]*1
Auto, PS, PCL, Imaging, PDF, XPS
Auto
Yes
No
[Mode Priority]*1
(See "Mode Priority.")
None, PS, PCL, PDF, XPS
None
Yes
No
[Color Mode]
Auto (Color/B&W), Black & White
Auto (Color/B&W)
Yes
Yes
[Compressed Image Output]
Output, Display Error
Output
Yes
Yes
[Initialize]
Yes, No
No
Yes
*1
Indicates items that appear only when the appropriate optional product is available for use or the appropriate setting is specified.
*2
Copies: 1 to 9999
*3
Staple Position (Staple+Collate, Staple+Group):
Corner (Upper-L), Double (Top), Corner (Upper-R), Double (Right), Corner (Lower-R), Double (Bottom), Corner (Lower-L), Double (Left).
*4
Staple Position (Eco(Stpl-Fr)+Col, Eco(Stpl-Fr)+Grp):
Corner (Upper-L), Corner (Upper-R), Corner (Lower-R), Corner (Lower-L).
UFR II Settings (Printer Settings > Custom Settings > UFR II)
Item
Setting Description
Default Setting
[Halftones]
Err Diffusion(600dpi Only): On, Off
Off
Yes
Yes
Text: Resolution, Gradation
Resolution
Graphics: Resolution, Gradation
Gradation
Image: Resolution, Gradation
Gradation
[Matching Method]
General, Perceptual, Colorimetric, Vivid Photo
General
Yes
Yes
[Gray Compensation]
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
[Paper Save]
On, Off
On
Yes
Yes
PCL Settings (Printer Settings > Custom Settings > PCL)
Item
Setting Description
Default Setting
[Paper Save]
On, Off
Off
Yes
Yes
[Orientation]
Portrait, Landscape
Portrait
Yes
Yes
[Font Number]
0 to 104
0
Yes
No
[Point Size]*1
4.00 to 999.75 point
12.00 point
Yes
No
[Pitch]*1
0.44 to 99.99 cpi
10.00 cpi
Yes
No
[Form Lines]
5 to 128 lines
60 lines
Yes
No
[Character Code]
ARABIC8, DESKTOP, GREEK8, HEBREW7, HEBREW8, ISO4, ISO6, ISO11, ISO15, ISO17, ISO21, ISO60, ISO69, ISOCYR, ISOGRK, ISOHEB, ISOL1, ISOL2, ISOL5, ISOL6, LEGAL, MATH8, MCTEXT, MSPUBL, PC775, PC8, PC850, PC851, PC852, PC862, PC864, PC866, PC8DN, PC8GRK, PC8TK, PC1004, PIFONT, PSMATH, PSTEXT, ROMAN8, VNINTL, VNMATH, VNUS, WIN30, WINARB, WINBALT, WINCYR, WINGRK, WINL1, WINL2, WINL5
PC8
Yes
Yes
[Custom Paper]
On, Off
Off
Yes
No
[Unit of Measure]*1
Millimeters, Inches
Inches
Yes
No
[X dimension]*1
3.88 to 47.24 inches
18.00 inches
Yes
No
[Y dimension]*1
3.88 to 12.59 inches
12.59 inches
Yes
No
[Append CR to LF]
Yes, No
No
Yes
Yes
[Enlarge A4 Print Width]
On, Off
Off
Yes
Yes
[Halftones]
Off
Yes
Yes
Resolution
Gradation
Gradation
[Matching Method]
General
Yes
Yes
[Gray Compensation]
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
[BarDIMM]
Enable, Disable
Disable
Yes
Yes
[FreeScape]*1
Off, ~, ", #, $, /, \, ?, {, }, |
Yes
Yes
*1
PS Settings (Printer Settings > Custom Settings > PS)
Item
Setting Description
Default Setting
[Job Timeout]
0 to 3600 seconds
0 second
Yes
Yes
[Print PS Errors]
On, Off
Off
Yes
Yes
[Pure Black Text]
On, Off
On
Yes
Yes
[Black Overprint]*1
On, Off
On
Yes
Yes
[RGB Source Profile]
sRGB, Gamma 1.5, Gamma 1.8, Gamma 2.4, None, Download Profile
sRGB
Yes
No
[CMYK Simulation Profile]
JapanColor(Canon, US Web Ctd(Canon, Euro Standard, None, Download Profile
None
Yes
No
[Use Grayscale Profile]
On, Off
Off
Yes
No
[Output Profile]
Text: Normal, Photo, TR Normal, TR Photo, Download Profile
Graphics: Normal, Photo, TR Normal, TR Photo, Download Profile
Image: Normal, Photo, TR Normal, TR Photo, Download Profile
TR Photo
TR Photo
TR Photo
Yes
No
[Matching Method]
Perceptual, Saturation, Colorimetric
Perceptual
Yes
Yes
[Halftones]
Off
Yes
Yes
Resolution
Gradation
Gradation
[Brightness]*1
85% to 115%
100%
Yes
Yes
[Composite Overprint]
On, Off
Off
Yes
Yes
[Grayscale Conversion]*1
sRGB, NTSC, Uniform RGB
NTSC
Yes
Yes
*1
Imaging Settings (Printer Settings > Custom Settings > Imaging) *1
Item
Setting Description
Default Setting
[Image Orientation]
Auto, Vertical, Horizontal
Auto
Yes
Yes
[Zoom Mode]
Off, Auto
Off
Yes
Yes
[Print Position]
Auto, Center, Top Left
Auto
Yes
Yes
[Show Warnings]
On, Off
On
Yes
Yes
[Enlarge Print Area]
On, Off
Off
Yes
Yes
[Matching Method]
General
Yes
Yes
[Photo Correct.(Color Only)]
[Photo Optimizer PRO]
On, Off
Off
Yes
No
[Red-Eye Correction]
Red-Eye Correction: On, Off
Off
Yes
No
Red-Eye Correction Level: Weak, Standard, Strong
Standard
[Face Brightener]
Face Brightener: On, Off
Off
Yes
No
Face Brightener Level: Weak, Standard, Strong
Standard
[Halftones]
Resolution, Gradation, Error Diffusion
Gradation
Yes
Yes
[Gray Compensation]
On, Off
On
Yes
Yes
[Grayscale Conversion]*2
NTSC
Yes
Yes
*1
Indicates items that appear only when using a Direct Print Printer.
*2
PDF Settings (Printer Settings > Custom Settings > PDF) *1
Item
Setting Description
Default Setting
[Enlarge/Reduce to Fit Size]
On, Off
Off
Yes
Yes
On, Off
Off
Yes
Yes
[N on 1]
Off, 2 on 1, 4 on 1, 6 on 1, 8 on 1, 9 on 1, 16 on 1
Off
Yes
Yes
[Comment Print]
Off, Auto
Auto
Yes
Yes
[Pure Black Text]
On, Off
On
Yes
Yes
[Black Overprint]*2
On, Off
On
Yes
Yes
sRGB
Yes
No
None
Yes
No
On, Off
Off
Yes
No
[Output Profile]
TR Photo
TR Photo
TR Photo
Yes
No
[Matching Method]
Perceptual
Yes
Yes
[Halftones]
Off
Yes
Yes
Resolution
Gradation
Gradation
[Brightness]*2
85% to 115%
100%
Yes
Yes
On, Off
Off
Yes
Yes
NTSC
Yes
Yes
*1
*2
XPS Settings (Printer Settings > Custom Settings > XPS) *1
Item
Setting Description
Default Setting
[Matching Method]
General
Yes
Yes
On, Off
Off
Yes
No
Off
Yes
No
Red-Eye Correction Level*2: Weak, Standard, Strong
Standard
[Face Brightener]
Off
Yes
No
Face Brightener Level*2: Weak, Standard, Strong
Standard
[Halftones]
Off
Yes
Yes
Text: Gradation, Resolution
Resolution
Graphics: Gradation, Resolution
Gradation
Image: Gradation, Resolution
Gradation
[Gray Compensation]
Text: On, Off
On
Yes
Yes
Graphics: On, Off
On
Image: On, Off
On
Text: sRGB, NTSC, Uniform RGB
NTSC
Yes
Yes
Graphics: sRGB, NTSC, Uniform RGB
NTSC
Image: sRGB, NTSC, Uniform RGB
NTSC
*1
*2
Utility Settings (Printer Settings > Utility)
Item
Setting Description
Default Setting
[Initialize PCL Hard Disk]
Yes, No
No
No
[Initialize PS Hard Disk]
Yes, No
No
No
[Reset Printer]
Yes, No
No
No
Printer
Item
Setting Description
Default Setting
[Restrict Printer Jobs]
On, Off
Off
Yes
Yes
When On is selected:
Allow Secure Print Jobs: Rsrvd Jobs, Rsrvd. Jobs + Sec. Print
Rsrvd Jobs
Yes
Yes
[PDL Selection (Plug and Play)]
UFR II, PCL5c, PCL6, PS3, UFR II (XPS), Fax*1
UFR II
Yes
No
*1
