Category Top
Settings/Registration and User Privileges
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Secure Print
Function Settings: Web Access
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Size and Type for a Paper Source
Setting the Paper Size Group for Auto Recognition in the Paper Source
Distinguishing A5R and STMTR Paper
Registering/Editing Custom Paper Types
Registering Paper Frequently Used in the Multi-Purpose Tray
Setting the Method for Selecting Multi-Purpose Tray Paper
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Display Fax Function
Store Location Display Settings
Changing the Display Language/Keyboard on the Touch Panel Display
Changing the Keyboard Shift Lock Feature Settings
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Displaying the Remaining Toner Error Message
Deleting the Remaining Toner Error Message
Displaying the IP Address
Timer/Energy Settings
Current Time Adjustment
Current Date and Time
Time Format
Quick Startup Settings
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Auto Sleep Weekly Timer Settings
Setting the Sleep Mode Exit Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Automatic Gradation Adjustment
Correct Density
Correct Shading
Auto Correct Color Mismatch
Making the Color More Vivid When Printing with Full Color
Fine Adjust Zoom
Dither Pattern Settings
Reducing Toner Used When Color Printing
Correcting Irregularities in Shaded Areas
Adjust Action
Saddle Stitch Staple Repositioning
Saddle Stitch Position Adjustment
Setting the Execution Time for Manual Stapling
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Specifying Paper Drawer Auto Selection Based on Color
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
Setting the Output Trays of Optional Equipment
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Print Settings
Setting the Printing Priority
Text/Photo Priority in a Black-and-White Original
Outputting Reports with Two-Sided Printing
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Scan Settings
Feeder Jam Recovery Method
Scanning Originals Quietly
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
Image Quality Level for Compact
Settings for Creating Searchable PDF/OOXML
Trace & Smooth Settings
OOXML Settings
Including Background Images When Generating Word Files
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Changing the PDF Encryption Level from Acrobat 10.0 or Equivalent to Acrobat 9.0 or Equivalent
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Enabling Auto Collating
Enabling Auto Orientation
Color Mode Settings for Copy
Send
Output Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Scan and Send
Changing the Default Settings for Scan and Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
Displaying a Confirmation Screen When Jobs Are Accepted
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN on Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Autocomplete for E-mail Address Entry
Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for Fax
Registering/Editing/Deleting Sender Names (TTI)
Setting the Authenticated User Name as the Sender Name
Enabling ECM Transmission
Pause Time
Enabling Auto Redial
Checking the Dial Tone before Sending
Fax TX Report
Fax Activity Report
Fax Line Settings
Setting the Line to Use When Sending
Send Start Speed
PIN Code Access
Remote Fax TX Settings
Receive/Forward
Output Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Interrupt Printing of Received Jobs
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Confirming/Enabling/Deleting Forwarding Settings
Printing Forwarding Settings
Specifying the Fax/I-Fax Inbox Settings
Always Send Notice for RX Errors
Fax Settings
Enabling ECM Reception
Fax RX Report
Confidential Fax Inbox RX Report
Setting the Receive Start Speed
Setting the Receive Password
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Mail Box Settings
Memory Media Settings
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Printing LDAP Server Settings
LDAP Server Auto Search
Registering/Editing LDAP Search Attributes
Registering/Editing/Deleting Default Search Conditions for Each LDAP Server
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Communication Timeout
Fax TX Line Auto Select Adjustment
Top » Settings/Registration » Settings/Registration Table » Preferences
Preferences
0R9W-059
Preferences: Paper Settings
Item
Setting Description
Default
Setting
Can be set in
Remorte UI
Device Information
Delivery Available
[Paper Settings]
Paper Source
Set:
Thin(14 bond-16 bond), Plain, Heavy 1(29 bond-34 bond), Heavy 2(35 bond-60 cover),  Heavy 3(61 cover-80 cover), Color(17 bond-21 bond), Recycled 1(17 bond-20 bond), Recycled 2(21 bond-24 bond), Recycled 3(25 bond-28 bond), Pre-Punched, Transparency
Custom Size: S1 to S4
Envelope: No. 10 (COM10), DL, ISO-C5, Monarch, Nagagata 3, Yougatanaga 3, Kakugata 2
Plain
Yes
No
<Plain Paper Basis Weight Settings>: Plain 1(17 bond-20 bond), Plain 2(21 bond-24 bond), Plain 3(25 bond-28 bond)
Yes
No
[Paper Size Group for Auto Recog. in Drawer]
Multi-Purpose Tray: A/B Size, Inch Size
Paper Drawer: All Sizes, A/B Size, Inch Size
Inch Size
[A5R/STMTR Paper Selection]
A5R, STMTR
STMTR
No
No
[Paper Type Management Settings]
Details/Edit
Name, Category, Basis Weight, Finish, Type, Color, Adjust Creep Correction
Yes
No
Duplicate, Delete
Yes
No
[Register Favorite Paper (Multi-Purpose Tray)]
P1 to P30: Register/Edit, Rename
No
No
Delete
No
No
[Multi-Purpose Tray Defaults]
Use Preset (Register)
Always Specify(Standard, Favorite Paper)
Always Specify(Standard)
No
No
[Register Custom Size]
S1 to S4:
No
Yes
Delete
No
No
Preferences: Display Settings
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Default Screen after Startup/Restoration]
Main Menu, Quick Menu, Copy, Fax*1, Scan and Send, Scan and Store, Access Stored Files, Fax/I-Fax Inbox, Secure Print, Scanner, Web Access*1, Tutorial, Dest./Fwd. Settings, Workflow Composer*1
Main Menu
No
No
Open Status Monitor/Cancel: On, Off
Off
No
No
[Default Screen (Status Monitor/Cancel)]
Default Status Type: Copy/Print, Send, Receive, Store, Consmbls./Others
Copy/Print
No
No
Status/Log: Job Status, Job Log
Job Status
No
No
Details (Copy/Print, Job Status): Print, Copy
No
No
Details (Send, Job Status): Send, Fax*1
No
No
Details (Receive, Job Status): Fax*1, Forward
No
No
Details (Copy/Print, Job Log): Copy, Printer, Local Print, Received Job Print, Print Report
No
No
Details (Send, Job Log): Send, Fax*1
No
No
Details (Receive, Job Log): Receive, Fax*1
No
No
[Display Fax Function]*1
On, Off
On
No
No
Enable Fax in Scan and Send Function: On, Off
On
No
No
[Store Location Display Settings]
Mail Box: On, Off
On
No
No
Network: On, Off
On
No
No
Memory Media: On, Off
On
No
No
[Switch Language/Keyboard]
Language, Keyboard Layout
No
No
[Use Keyboard Shift Lock Feature]
On, Off
Off
No
Yes
[Display Remaining Paper Message]
On, Off
On
No
No
[No. of Copies/Job Duration Status]
On, Off
On
No
No
[Notify to Clean Original Scanning Area]
On, Off
On
No
No
[Paper Type Selection Screen Priority]
Simple, Detailed
Simple
No
No
[Switch Millimeter/Inch Entry]
mm, Inch
Inch
No
Yes
[ID/User Name Display On/Off]
On, Off
On
No
No
[Display Remaining Toner Error Message]
On, Off
Off
No
No
[Delete Remaining Toner Error]
Yes, No
No
No
[IP Address Display Settings]
On, Off
On
No
No
*1
Indicates items that appear only when the appropriate optional product is available for use.
Preferences: Timer/Energy Settings
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Adjust Time]
00:00 to 23:59, in one minute increments
No
No
[Date/Time Settings]
Date and Time Setting (12 digit number)
Yes
No
Time Zone: GMT-12:00 to GMT+12:00
GMT-05:00
Yes
No
Daylight Saving Time: On, Off
Off
Yes
No
Start Date (Month/Day/Time (0 to 23))
April, 1st, Sunday, 2:00
Yes
No
End Date (Month/Day/Time (0 to 23))
October, Final, Sunday, 2:00
Yes
No
[Time Format]
24 Hour, 12 Hour
12 Hour
Yes
No
[Quick Startup Settings for Main Power]
On, Off
On
Yes
Yes
Startup Speed Priority: On, Off
On
Yes
No
[Auto Reset Time]
0 min=Off, 10 to 50 seconds in 10 second increments, 1 to 9 minutes in one minute increments
2 mins
Yes
Yes
[Restrict Auto Reset Time]
On, Off
Off
Yes
Yes
[Function After Auto Reset]
Initial Function, Selected Function
Initial Function
Yes
Yes
[Auto Sleep Time]
10 seconds, 1, 2, 10, 15, 20, 30, 40, 50 mins, 1 hr, 90 mins, 2, 3, 4 hrs
1 min*1
Yes
Yes
[Sleep Mode Energy Use]
Low, High
Low
Yes
Yes
[Auto Sleep Weekly Timer]
Sun to Sat, 00:00 to 23:59, in one minute increments
Yes
Yes
[Sleep Mode Exit Time Settings]
Yes
Yes
*1
It is recommended that you use the default setting for this item.
Preferences: Network
If you are configuring the settings for the first time in "Interface Settings," "TCP/IPv4 Settings," "TCP/IPv6 Settings," or "Settings Common to TCP/IPv4 and TCP/IPv6," use the control panel of the machine. After configuring the TCP/IP settings, you can change them using the Remote UI.
If you are using a AppleTalk network, you must use the TCP/IP protocol if you want to specify settings using software other than the control panel of the machine.
Output Report(See "Confirming Settings.")
Item
Setting Description
Default Setting
Can be set in Remote UI
Device Information Delivery Available
[Output Report]
Yes, No
Yes
No
Confirm Network Connection Set. Changes(See "Interface Settings.")
Item
Setting Description
Default Setting
[Confirm Network Connection Set. Changes]
On, Off
Off
No
Yes
TCP/IP Settings: IPv4 Settings(See "TCP/IPv4 Settings.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv4 Settings]
[Use IPv4]
On, Off
On
Yes
No
[IP Address Settings]
IP Address
0.0.0.0
Yes
No
Subnet Mask
0.0.0.0
Yes
No
Gateway Address
0.0.0.0
Yes
No
DHCP: On, Off
On
Yes
Yes
Auto IP: On, Off
Off
Yes
No
[DHCP Option Settings]
Acquire Host Name: On, Off
On
Yes
No
DNS Dynamic Update: On, Off
Off
Yes
No
[PING Command]
IPv4 Address
0.0.0.0
No
No
TCP/IP Settings: IPv6 Settings(See "TCP/IPv6 Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv6 Settings]
[Use IPv6]
On, Off
Off
Yes
No
[Stateless Address Settings]
Use Stateless Address: On, Off
On
Yes
No
[Manual Address Settings]
Use Manual Address: On, Off
Off
Yes
No
Manual Address (IPv6 Address (39 characters maximum))
Yes
No
Prefix Length: 0 to 128
64
Yes
No
Default Router Addr. (39 characters maximum)
Yes
No
[Use DHCPv6]
On, Off
Off
Yes
Yes
[PING Command]
No
No
Host Name
No
No
[Only Retrieve Stateful Address Prefix]
On, Off
Off
Yes
No
TCP/IP Settings: DNS Settings(See "TCP/IPv4 Settings.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[DNS Settings]
[DNS Server Address Settings]
Primary DNS Server (IPv4 Address)
0.0.0.0
Yes
No
Secondary DNS Server (IPv4 Address)
0.0.0.0
Yes
No
[DNS Host/Domain Name Settings]
Host Name
Canon****** ("******" represents the last six digits of a MAC address.)
Yes
No
Domain Name
(NULL)
Yes
No
[DNS Dynamic Update Settings]
Off
Yes
No
[mDNS Settings]
Use IPv4 mDNS: On, Off
Off
Yes
No
mDNS Name (63 characters maximum)
(NULL)
Yes
No
TCP/IP Settings: DNS Settings(See "TCP/IPv6 Settings.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[DNS Settings]
Primary DNS Server (IPv6 Address)
Yes
No
Secondary DNS Server (IPv6 Address)
Yes
No
Use Same Host Name/Domain Name as IPv4: On, Off
Off
Yes
No
Host Name
Yes
No
Domain Name
Yes
No
Off
Yes
No
Register Stateless Address: On, Off
Off
Yes
No
Register Manual Address: On, Off
Off
Yes
No
Register Stateful Address: On, Off
Off
Yes
No
[mDNS Settings]
Use IPv6 mDNS: On, Off
Off
Yes
No
Use Same mDNS Name as IPv4 mDNS: On, Off
Off
Yes
No
(NULL)
Yes
No
TCP/IP Settings
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Computer Name/Workgroup Name Settings]
Computer Name (15 characters maximum)
Yes
No
Workgroup Name (15 characters maximum)
WORKGROUP
Yes
No
Comment (48 characters maximum)
(NULL)
Yes
No
[WINS Settings]
WINS Resolution: On, Off
Off
Yes
No
WINS Server Address (IP Address)
0.0.0.0
Yes
No
Node Type: Auto (display only)
No
No
Scope ID
(NULL)
Yes
No
[LPD Print Settings]
On, Off
On
Yes
Yes
Output LPD Banner Page*1: On, Off
Off
Yes
Yes
RX Timeout: 1 to 60 min.
5 min.
Yes
Yes
[RAW Print Settings]
On, Off
On
Yes
Yes
Bidirectional Communication: On, Off
Off
Yes
Yes
5 min.
Yes
Yes
[SNTP Settings]
Use SNTP: On, Off
Off
Yes
No
Polling Interval: 1 to 48 hr., in one hour increments
24
Yes
No
NTP Server Address (IP Address or Host Name)
(NULL)
Yes
No
Check NTP Server
Yes
No
[FTP Print Settings]
Use FTP Printing: On, Off
Off
Yes
Yes
User Name
guest
Yes
No
Password
7654321
Yes
No
[Use UTF-8 to Display Name of FTP Print Job]
On, Off
Off
Yes
No
[WSD Settings]
Use WSD: On, Off
Off
Yes
Yes
Use WSD Browsing: On, Off
Off
Yes
Yes
Use WSD Scan Function: On, Off
Off
Yes
Yes
[Use FTP PASV Mode]
On, Off
Off
Yes
Yes
[IPP Print Settings]
On, Off
Off
Yes
Yes
Use SSL: On, Off
Off
Yes
No
Use Authentication: On, Off
On
Yes
No
User Name
guest
Yes
No
Password
7654321
Yes
No
[Multicast Discovery Settings]
Response: On, Off
On
Yes
Yes
Scope Name
default
Yes
No
[Use HTTP]
On, Off
On
Yes
Yes
[SSL Settings]
Settings that use SSL
Yes
No
[Key and Certificate]
Set as the Default Key
Yes
No
Certificate Details (Version, Serial Number, Signature Algorithm, Issued To, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Display Use Location (Displays what the key pair is being used for)
Yes
No
[Proxy Settings]
Use Proxy: On, Off
Off
Yes
No
Server Address (IP Address or FQDN)
(NULL)
Yes
No
Port Number: 1 to 65535
80
Yes
No
Use Proxy within the Same Domain: On, Off
Off
Yes
No
[Set Authentication]
Use Proxy Auth.: On, Off
Off
Yes
No
User Name
(NULL)
Yes
No
Password
(NULL)
Yes
No
[Confirm Dept. ID PIN]
On, Off
Off
Yes
No
*1
IPSec Settings(See "IPSec Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPSec Settings]
<Use IPSec>
On, Off
Off
Yes
No
<Receive Non-Policy Packets>
Allow, Reject
Allow
Yes
No
[Policy On/Off]
On, Off
Off
Yes
No
[Reg.]
Policy Name (24 characters maximum)
(NULL)
Yes
No
[Selector Settings]
Local Address(All IP Addr., IPv4 Address, IPv6 Address, IPv4 Manual Settings, IPv6 Manual Settings)
All IP Addr.
Yes
No
IPv4 Manual Settings(Single Address, Address Range(First Address, Last Address), Subnet Settings(Address, Subnet Mask))
Single Address
Yes
No
IPv6 Manual Settings (Single Address(Address), Address Range (First Address, Last Address), Specify Prefix (Address, Prefix Length))
Single Address
Yes
No
Prefix Length (0 to 128)
64
Yes
No
Remote Address(All IP Addr., All IPv4 Addr., All IPv6 Addr., IPv4 Manual Settings, IPv6 Manual Settings)
All IP Addr.
Yes
No
Single Address
Yes
No
Single Address
Yes
No
64
Yes
No
Port (Specify by Port Number, Specify by Service Name)
Yes
No
Specify by Port Number(Local Port(All Ports, Single Port), Remote Port(All Ports, Single Port))
All Ports
Yes
No
Single Port (1 to 65535)
0
Yes
No
Service On/Off: On, Off
Off
Yes
No
[IKE Settings]
IKE Mode: Main, Aggressive
Main
Yes
No
Authentication Method: Pre-Shared Key Method (Shared Key), Digital Sig. Method (Key and Certificate)
Yes
No
Key and Certificate:
Yes
No
Certificate Details(Version, Serial Number, Signature Algorithm, Issued To, Validity Start Date, Validity End Date, Issuer, Public Key, Certificate Thumbprint, Verify Cert.)
Yes
No
Yes
No
Auth./Encryption Algorithm (Auto, Manual Settings)
Auto
Yes
No
Auth./Encryption Algorithm: Manual Settings
Authentication
SHA1: On, Off
SHA2: On, Off
On
On
Yes
Yes
No
No
Encryption
3DES-CBC: On, Off
AES-CBC: On, Off
On
Off
Yes
Yes
No
No
DH Group:
Group 1 (768), Group 2 (1024), Group 14 (2048), ECDH-P256, ECDH-P384
Group 2 (1024)
Yes
No
[IPSec Network Settings]
Validity
Time: On, Off
On
Yes
No
On: (1 to 65535 min.)
480 min.
Yes
No
Validity
Off
Yes
No
On: (1 to 65535 MB)
65535 MB
Yes
No
PFS: On, Off
Off
Yes
No
Auth./Encryption Algorithm: Auto, Manual Settings
Auto
Yes
No
Auth./Encryption Algorithm: Manual Settings (ESP, ESP (AES-GCM), AH (SHA1))
ESP
Yes
No
ESP Settings:
ESP Auth.
SHA1: On, Off
NULL: On, Off
On
Off
Yes
Yes
No
No
ESP Encryption
3DES-CBC: On, Off
AES-CBC: On, Off
NULL: On, Off
On
Off
Off
Yes
Yes
Yes
No
No
No
ESP (AES-GCM) Settings: None
Yes
No
AH (SHA1) Settings: None
Yes
No
Connect. Mode:
Transport (display only)
No
No
[Edit]
Yes
No
[Delete]
Yes
No
[Print List]
Yes, No
No
No
AppleTalk Settings(See "Protocol Settings.")
Item
Setting Description
Default Setting
[AppleTalk Settings]
<Use AppleTalk>
On, Off
Off
Yes
Yes
<Phase>
Phase 2 (display only)
No
No
[Service Name]
Name
Device Name
Yes
No
[Zone]
Zone
Yes
No
<Print Mode>*1
Both, Spool, Direct
Both
Yes
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
SNMP Settings(See "Communication Environment Setup.")
Item
Setting Description
Default Setting
Can be set in
Remote UI
Device Information
Delivery Available
[SNMP Settings]
<Use SNMPv1>
On, Off
On
Yes
Yes
[Dedicated Community Set.]
Dedicated Community: On, Off
On
Yes
No
MIB Access Permission: Read/Write, Read Only
Read Only
Yes
No
[Set Community Name 1]
Community Name 1: On, Off
On
Yes
No
Read Only
Yes
No
Community Name
public
Yes
No
[Set Community Name 2]
Community Name 2: On, Off
Off
Yes
No
Read Only
Yes
No
Community Name
public2
Yes
No
<Use SNMPv3>
On, Off
Off
Yes
No
[User Settings]
User On/Off: On, Off
On
Yes
No
Reg. (User Name, MIB Access Permis. (Read/Write, Read Only), Security Settings (Auth. Yes/Encry. Yes, Auth. Yes/Encry. No, Auth. No/Encrypt. No), Authent. Algorithm (MD5, SHA1), Authent. Password, Encryption Algorithm (DES, AES), Encryption Password)
Yes
No
Details/Edit (User Name, MIB Access Permis. (Read/Write, Read Only), Security Settings (Auth. Yes/Encry. Yes, Auth. Yes/Encry. No, Auth. No/Encrypt. No), Authent. Algorithm (MD5, SHA1), Authent. Password, Encryption Algorithm (DES, AES), Encryption Password)
Yes
No
Delete
Yes
No
[Context Settings]
Register (Context name)
Yes
No
Edit (Context name)
Yes
No
Delete
Yes
No
<Retrieve Printer Mgmt. Info. from Host>
On, Off
Off
Yes
Yes
[Reject SNMP Packets While in Sleep Mode]
On, Off
Off
Yes
No
Format Host Resources MIB to RFC2790(See "Communication Environment Setup.")
Item
Setting Description
Default Setting
[Format Host Resources MIB to RFC2790]
On, Off
On
No
No
Dedicated Port Settings(See "Communication Environment Setup.")
Item
Setting Description
Default Setting
[Dedicated Port Settings]
On, Off
On
Yes
Yes
Use Spool Function(See "Communication Environment Setup.")
Item
Setting Description
Default Setting
[Use Spool Function]
On, Off
Off
Yes
Yes
Waiting Time for Connection at Startup(See "Waiting Time for Connection at Startup.")
Item
Setting Description
Default Setting
[Waiting Time for Connection at Startup]
0 to 300 sec.
0 sec.
Yes
No
Ethernet Driver Settings(See "Interface Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Ethernet Driver Settings]
<Auto Detect>
On, Off
On
Yes
No
<Communication Mode>
Off: Half Duplex, Full Duplex
Half Duplex
Yes
No
<Ethernet Type>
Off: 10BASE-T, 100BASE-TX, 1000BASE-T
10BASE-T
Yes
No
<Current Transmission Speed>
Display Only
Yes
No
<MAC Address>
Display only
No
No
IEEE 802.1X Settings(See "Selecting the IEEE802.1X Authentication Method.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IEEE 802.1X Settings]
<Use IEEE 802.1X>
On, Off
Off
Yes
No
[Login Name]
Login Name
(NULL)
Yes
No
<Verify Authentication Server>
On, Off
Off
Yes
No
[Auth. Server Name]
Auth. Server Name
(NULL)
Yes
No
<Use TLS>
On, Off
Off
Yes
No
Yes
No
Yes
No
Display Use Location (Key and Certificate)
Yes
No
<Use TTLS>
On, Off
Off
Yes
No
<TTLS Settings (TTLS Protocol)>: MSCHAPv2, PAP
MSCHAPv2
Yes
No
<Use PEAP>
On, Off
Off
Yes
No
[User Name]
Name of the user to be authenticated with IEEE802.1X authentication
(NULL)
Yes
No
[Password]
Password of the user to be authenticated with IEEE802.1X authentication
(NULL)
Yes
No
[Same User Name as Login Name]
On, Off
On
Yes
No
Firewall Settings: IPv4 Address Filter(See "TCP/IPv4 Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv4 Address Filter]
[Outbound Filter]
Use Filter: On, Off
Off
Yes
No
Default Policy: Allow, Reject
Allow
Yes
No
Register (Up to 16 IPv4 addresses), Edit, Delete
Yes
No
Register
Single Address, Address Range (First Address, Last Address), Specify Prefix (Address, Prefix Length)
Edit
Single Address
Yes
No
Prefix Length (0 to 32)
Yes
No
[Inbound Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 16 IPv4 addresses), Details/Edit, Delete
Yes
No
Register
Single Address, Address Range (First Address, Last Address), Specify Prefix (Address, Prefix Length), Port Number (Do Not Specify, Specify)
Specify (Port Number): Add, Delete
Single Address
Yes
No
Details/Edit
Yes
No
Yes
No
Firewall Settings: IPv6 Address Filter(See "TCP/IPv6 Settings.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IPv6 Address Filter]
[Outbound Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 16 IPv6 addresses), Edit, Delete
Yes
No
Register
Single Address (Address), Specify Prefix (IPv6 Prefix, Prefix Length)
Edit
Single Address
Yes
No
Yes
No
[Inbound Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 16 IPv6 addresses), Details/Edit, Delete
Yes
No
Register
Single Address (Address), Specify Prefix (IPv6 Prefix, Prefix Length), Port Number (Do Not Specify, Specify)
Single Address
Yes
No
Details/Edit
Yes
No
Yes
No
Firewall Settings: MAC Address Filter(See "Settings Common to TCP/IPv4 and TCP/IPv6.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[MAC Address Filter]
[Outbound Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Register (Up to 100 Mac addresses), Edit, Delete
Yes
No
[Inbound Filter]
Use Filter: On, Off
Off
Yes
No
Allow
Yes
No
Yes
No
Firewall Settings: IP Address Block Log(See "Checking the Block Log.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[IP Address Block Log]
Date, Type, IP Address, Port Number, Result, Details(Date, Type, IP Address, Port Number, Result)
Yes
No
Preferences: External Interface
USB Settings(See "Using the USB Port.")
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[USB Settings]
[Use as USB Device]
On, Off
On
Yes
Yes
[Use MEAP Driver for USB Input Device]
On, Off
Off
Yes
Yes
[Use MEAP Driver for USB Storage Device]
On, Off
Off
Yes
Yes
Preferences: Accessibility
Item
Setting Description
Default
Setting
Can be set in
Remote UI
Device Information
Delivery Available
[Key Repetition Settings]
Standard, Slightly Slow, Slow
Standard
No
No
[Reversed Display (Color)]
On, Off
Off
No
No
Some items can be set using the Remote UI. Use the control panel of the device to set items which cannot be set using the Remote UI.
The names may be different on the Remote UI.
