Category Top
Clearing Paper Jams
Locations of Paper Jams
Main Unit
Right Cover of the Machine
Right Cover of the Machine (When the Multi-drawer Paper Deck-A1 is attached)
Left Cover of the Machine
Left Cover of the Machine (When the Buffer Pass Unit-J1 is attached)
Fixing Transport Unit
Paper Sources
Multi-purpose Tray
Paper Drawers 3 and 4
Paper Drawers (Right/Left)
Paper Deck Unit-C1/POD Deck Lite-A1 (Optional)
Front Cover of the Multi-drawer Paper Deck-A1 (Optional)
Paper Decks of the Multi-drawer Paper Deck-A1 (Optional)
Duplex Color Image Reader Unit-F1 (Optional)
Buffer Pass Unit-J1
Document Insertion Unit-H1 (Optional)
Professional Puncher Integration Unit-B1 (Optional)
Paper Folding Unit-G1 (Optional)
Staple Finisher-K1 (Optional)
Booklet Finisher-K1 (Optional)
Inside the Front Cover
Saddle Stitcher Unit
Document Insertion/Folding Unit-G1/Document Insertion Unit-J1 (Optional)
Insertion Unit
Inside the Insertion Unit
Folding Unit
External 2/3 Hole Puncher-A1 (Optional)
Staple Finisher-L1/Booklet Finisher-L1 (Optional)
Inside the Top Cover
Output Area
Front Cover of the Booklet Finisher-L1
Saddle Stitcher Unit of the Booklet Finisher-L1
Reducing the Frequency of Paper Jams
Clearing Staple Jams (For Optional Products)
Locations of Staple Jams
Stapler Unit of the Staple Finisher-K1/Booklet Finisher-K1
Saddle Stitcher Unit of the Booklet Finisher-K1
If Memory Becomes Full During Scanning
If OCR (Text Searchable) Performs Inadequately
Printer/Fax Driver Troubleshooting
Service Call Message
List of Error Messages
General
Fax
Scan and Send
Scan and Store/Access Stored Files
Quick Menu
Printer
Network/Security
MEAP
User Setting Information Management
List of Error Codes without Messages
Top » Problem Solving » Clearing Staple Jams (For Optional Products) » Saddle Stitcher Unit of the Booklet Finisher-K1
08JK-0R8
Check the location of the staple jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed staple.
Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste, discard the trim waste, discard the staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
Before clearing the staple jam, remove all output sheets from the booklet tray.
The Booklet Finisher-K1 is an optional product.
If a paper jam occurs at the same time as a staple jam, remove the jammed paper before removing the jammed staples.
Open the front cover of the finisher.
Pull out the staple case from the saddle stitcher unit (F-C5).
1. Pull out the saddle stitcher unit (F-C5).
2. Pull out the staple case.
Hold the staple case by its left and right sides, and lower the bracket on the staple case.
4.
Remove the jammed and exposed staples from the staple case.
5.
Return the bracket on the staple case to its original position.
6.
Return the staple case to its original position in the saddle stitcher unit.
When returning the staple case, always make sure to the staple case is inserted until the arrows are aligned as shown in the diagram.
7.
Push the saddle stitcher unit (F-C5) back into the machine, and close the front cover of the finisher.
1. Gently push the saddle stitcher unit back into the machine.
Always make sure to push the saddle stitcher unit in as far as it can go.
2. Close the front cover of the finisher.
CAUTION
When returning the saddle stitcher unit and closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
