Category Top
Clearing Paper Jams
Locations of Paper Jams
Main Unit
Right Cover of the Machine
Right Cover of the Machine (When the Multi-drawer Paper Deck-A1 is attached)
Left Cover of the Machine
Left Cover of the Machine (When the Buffer Pass Unit-J1 is attached)
Fixing Transport Unit
Paper Sources
Multi-purpose Tray
Paper Drawers 3 and 4
Paper Drawers (Right/Left)
Paper Deck Unit-C1/POD Deck Lite-A1 (Optional)
Front Cover of the Multi-drawer Paper Deck-A1 (Optional)
Paper Decks of the Multi-drawer Paper Deck-A1 (Optional)
Duplex Color Image Reader Unit-F1 (Optional)
Buffer Pass Unit-J1
Document Insertion Unit-H1 (Optional)
Professional Puncher Integration Unit-B1 (Optional)
Paper Folding Unit-G1 (Optional)
Staple Finisher-K1 (Optional)
Booklet Finisher-K1 (Optional)
Inside the Front Cover
Saddle Stitcher Unit
Document Insertion/Folding Unit-G1/Document Insertion Unit-J1 (Optional)
Insertion Unit
Inside the Insertion Unit
Folding Unit
External 2/3 Hole Puncher-A1 (Optional)
Staple Finisher-L1/Booklet Finisher-L1 (Optional)
Inside the Top Cover
Output Area
Front Cover of the Booklet Finisher-L1
Saddle Stitcher Unit of the Booklet Finisher-L1
Reducing the Frequency of Paper Jams
Clearing Staple Jams (For Optional Products)
Locations of Staple Jams
Stapler Unit of the Staple Finisher-K1/Booklet Finisher-K1
Saddle Stitcher Unit of the Booklet Finisher-K1
If Memory Becomes Full During Scanning
If OCR (Text Searchable) Performs Inadequately
Printer/Fax Driver Troubleshooting
Service Call Message
List of Error Messages
General
Fax
Scan and Send
Scan and Store/Access Stored Files
Quick Menu
Printer
Network/Security
MEAP
User Setting Information Management
List of Error Codes without Messages
Top » Problem Solving » Clearing Paper Jams » Staple Finisher-L1/Booklet Finisher-L1 (Optional) » Inside the Top Cover
08JK-0R0
Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
Open the front cover of the finisher.
*1 Booklet Finisher-L1
*2 Staple Finisher-L1
If the Document Insertion/Folding Unit-G1 or Document Insertion Unit-J1 is attached, open the insertion unit. (See "Document Insertion/Folding Unit-G1/Document Insertion Unit-J1.")
Open the top cover of the finisher.
Remove any paper jammed from the top cover of the finisher.
1. Remove any jammed paper.
2. Close the top cover of the finisher.
If you open the Document Insertion/Folding Unit-G1 or Document Insertion Unit-J1 in step 1, close the insertion unit.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
4.
Close the front cover of the finisher.
CAUTION
5.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
